Doing some tree trimming
   / Doing some tree trimming
I considered the alternatives & the Stihl was the only option for me to get the job done in a reasonable amount of time & with the minimum of fuss & complexity. I am hoping to have things much more mower friendly before next season kicks off. Luckily, the wife doesn't have a problem with my picking up tools to get things done. As I get older & the effects of past injuries add up, I am more inclined to let the tool do the work when possible :).
Nick
   / Doing some tree trimming #22
I began with manual telescoping saw and it is still the height champ and works great for smaller limbs high up. Not hard to use. Then found out my Royobi had pole saw attachment for it from Sears which was made I think for Poulan. Seems like there were a few brands that used the same tools with different stick on labels. This is truly not a commercial setup but it can not be beat for the price. Not sure the reach but think at least ten feet. Was looking recently at buying commercial pole saw and decided on the commercial multi use set up when I happened to ask the dealer did they rent those and yes was the answer. Think it is $50 per day and if I plan the work one or two days will take care of my needs for at least two years and at that it would take at least ten rental days to pay for the saw which for me would be more years than I likely to be able to use one.
   / Doing some tree trimming #23
I have a Stihl pole saw attachment for my Stihl Kombi motor. I also have one extension pole. The Stihl with a sharp chain is handy when you are clearing trails from high wind downed trees. An oak that falls across the trail has a number of good sized limbs 6-8 feet off the ground. That is a height that the pole saw lets you get to while still keeping your distance. I was cutting some oak branches 8-10 inches thick with the pole saw. Once they were clear enough I could go after what was left with my MS210 and MS310, 16 and 24" bars. I also cursed those same big limbs when they twisted and got the saw stuck. Wedges and a little hatchet are your friends when you do not read the branches correctly. Some of that tree trimming was on rails to trails paths where the sides slope down sort of steeply. The trees would have been easier to deal with on flat ground.
   / Doing some tree trimming #24
I've been using manual pole saws for years. One is a Sears with a blade and a cutter. It has four extensions....even gets the kids' kites, rockets and parachutes out of the trees.
Anyway I just bought a Stihl HT-103 and on its first use I felt like a Cave Man that had just discovered the wheel. 014.JPG002.JPG008.JPG
Cheers,
Mike
   / Doing some tree trimming #25
Anyone have any issues with the telescopic Stihl Pole Saws?
The one in the family was in for warranty several times... used around the farm when needed... maybe once a month.
   / Doing some tree trimming #26
My HT-131 is a couple years old now and has been perfect. Granted it has not been used day in and day out but it will lay down more limbs in my yard than I care to deal with in a hurry. They have replaced my model now with a new version. I think it is just like a lot of things, take care of them and don't abuse them and they will do the job they were designed for.
   / Doing some tree trimming #27
I just ordered an Echo Pole PPF-225 saw from my local Mom and Pop... could have bought it for the same price Home Depot online but my saw shop stands behind what they sell...
Brother bought Stihl extended Pole Saw two years ago and has had a lot of problems with the extended part disengaging the drive... heard it has been redesigned now.
Never had a bad anything Echo so I went that way and it is not telescopic...
Hope to accomplish what you are doing soon!
For those of you thinking of ordering an Echo product they have a one day promotion event listed here and it's 20% off. California lists 14 sites. It's dealer specific, not all dealers do it, but it makes their prices a lot less than Home Depot etc.
   / Doing some tree trimming #28
Yep... I thought about is and would save about $80 but the nearest one would be over an hour each way and generally heavy traffic... good suggestion though!
Most of these type of events seem to bypass San Francisco and surrounding area... didn't have a Kubota Dealer in several counties here.
   / Doing some tree trimming #29
I bought a Power Pruner about 20 years ago, before they got bought out by Echo. I can reach about 13 ft., someone younger and stronger can probably go another 3 ft. or so. Power is from "the little engine that could." Never any engine problems, but the bar oil drains out after use and I lay it on a bucket lid to catch the mess.
Don't try to reach too high as the limb will start to fall and pinch the bar. For high limbs I start out near the end and work my way in so there won't be much weight to pinch the bar.
When I fall a tree I sometimes break out the pruner to cut the limbs that are down near the ground so I don't have to bend over so much.
   / Doing some tree trimming #30
I’ve got a Stihl HT131, works great, but it’s a workout over extended periods. I still have my old Echo PAS 240 split shaft with “power pruner” attachment, but never use it. I have a lot of low hanging branches to trim around the field edges that never seem to end.
1995 Rinker Captiva 190 (A56435)
1995 Rinker...
Mobile Transformer and Power Substation Portable Power Supply (A55302)
Mobile Transformer...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A55973)
2015 GMC 3500 HD...
2007 International 4300 (A53314)
2007 International...
2021 CATERPILLAR TL943D TELESCOPIC FORKLIFT (A52705)
2021 CATERPILLAR...
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
