How to cut mule tape?
   / How to cut mule tape? #1
Pilot
Oregon
JD 770, Yanmar 180D, JD 420 (not running), had a Kubota B6200
A friend gave me 250 foot sections of mule tape they throw away at work. Mule tape for those who don't know is a combination of a wire and nylon (or polyester?) and it lies flat. Very strong. Pretty handy stuff, but it is very difficult to cut with the combination of a wire (steel?) and nylon. Anybody have a good way to cut it? Knife doesn't work unless you have already cut the steel-and it takes a sharp knife at that. Band saw grabs it, pulls it out of your hands. Chop saw doesn't work. Sheet metal shears cut the wire, but not the nylon.
What does work?
   / How to cut mule tape? #2
Plasma gun? :D
   / How to cut mule tape? #3
I would imagine that a skinny wheel or one of those muffler cutters that use the small abrasive wheels would zip right through it.
What was it intended for, kind of a strapping?
   / How to cut mule tape? #4
Clamp it between two pieces of wood and use a circular saw with metal cutting blade.
Power sheers?
   / How to cut mule tape? #5
Power sheers?
I vote for the circular saw.
   / How to cut mule tape? #6
I'd say an abrasive cut off wheel would cut it. Maybe lay it across a block and use an axe.
   / How to cut mule tape? #7
If it's like mule tape I'm familiar with, the wire is only like 26 ga or 29 ga, and has either one or two strands. Not much to cut with a good knife or utility sheers; unless you have something different than I'm used to.
   / How to cut mule tape? #8
I have always cut it with a knife as well.
   / How to cut mule tape? #9
Interesting. Never heard of this stuff before. How about wire cutters and then scissors?
   / How to cut mule tape? #10
Funny, I have never seen this with a metal strand. I was thinking of using some in my dishwasher earlier today as the (parachute) cord that tensions the door came off the roller and rubbed through. But thought it too flat to negotiate the pulleys. I just cut it with side cutters. That stuff is VERY strong. Why the metal strand?
I use linesmens pliars, small bolt cutters or even vice grips to cut 440 stainless antenna whips, so they should cut whatever is in that tape.
   / How to cut mule tape? #11
The muletape I’m thinking of is used to pull wire etc through conduit. That would make sense as a lot of jobs spec that it is only used once. The folks on the job end up with a bunch of it. We use a heavy duty scissor type cutter or sharp aviation snips.
   / How to cut mule tape? #12
What does work?
Get a new set of shears or tighten the bolt on yours after you sharpen them a little.
Sounds like duct tape on steroids:thumbsup:
   / How to cut mule tape? #13
   / How to cut mule tape? #14
Poor guy. Needs a longer shirt or a moo-moo!
   / How to cut mule tape? #15
Regular 1800lb mule tape does not have wire in it and cuts with sharp shears, some of it has a small orange tracer wire woven it, but itç—´ soft and cuts easily too. Can you post a picture of what you have?
This is what telecom guys mean when they says 都hears? Amazon.com : Klein Tools 21-7 Electrician's Scissors, Nickel Plated : Klein Tools : Office Products
Those are exactly what we always used to cut mule tape with. But ours didn't have any steel in it that I remember.
   / How to cut mule tape? #16
Exactly. That is what "mule tape" means to me also. We used it to pull heavy cables thru conduits in the Telecom industry.
   / How to cut mule tape? #17
I used to get it free at work also, and it is awesome. Very easy to untie if you need to tie knots in it.
I have always used a knife to cut it, there is no wire imbedded in any of mine though.
   / How to cut mule tape? #18
I have scrounged mule tape with the wire in it, also. I don't like it with wire and you can pull the wire out in sections so as to have just the flat nylon part. Burn the ends of your tape to stop it from fraying. One neat use for the longer lengths I use is for hunting. I have had deer and hogs go running/rolling down the bluff where I hunt and a couple pulleys attached to trees brings them right back up.
   / How to cut mule tape? #19
I use mule tape all the time for tying light stuff down for transporting. Works great for tying down tarps and such, and I like that you can always get the knot back apart afterwards, even if it's wet. I've only ever just cut it with a sharp knife, but I've not had (or remember seeing) the kind you describe with metal strands in it.
   / How to cut mule tape? #20
poultry shears
1999 Wallace Trailers Tri Axle Low Boy Equipment Trailer (A59230)
1999 Wallace...
Lufkin 45ft. 40 Ton T/A Flatbed Trailer (A59230)
Lufkin 45ft. 40...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
Gravely Pro Turn 460 60in. Zero Turn Commercial Mower (A59228)
Gravely Pro Turn...
2018 VOLVO EC480EL EXCAVATOR (A60429)
2018 VOLVO EC480EL...
