uglychicken2005
New member, first post, first tractor!
When I'm back dragging with some pressure on the bucket (Front tires off the ground) and I try to feather it out by just
curling up my bucket the bucket just goes limp as soon as my tires are back on the ground that is? I can raise my fel and get off the tractor at that time and actually lift the bucket by hand!
Once I curl it some more it's stiff again. I went to the dealer and tried some other Mahindras on the lot and they did it to? Is there a way to fix this? I can make this happen at low or high rpm.
Also when dumping a load at low rpm my bucket will pause at about 45 degrees from level and then continue to dump?
Any thoughts?
Any thoughts?
