Ford 1510 - what to do for winter storage?
   / Ford 1510 - what to do for winter storage? #1
jingalsb
Northern Michigan
Ford 1510
Hi again, I have a 1983 Ford 1510 3 cyl diesel. What should I do before putting it in my outbuilding for the winter? I have no heat in there so it will get pretty cold in Northern Michigan.
   / Ford 1510 - what to do for winter storage? #2
If you have power in the building, you should put a trickle charger on the battery.
If no power, you could use a 12V solar trickle charger, or you could take the battery out of your machine, and put in a heated building with a trickle charger attached.
Last option: You could just buy a new battery each year.
   / Ford 1510 - what to do for winter storage? #3
I place a block of wood between the clutch rod and floor board (clutch disengaged) to make sure the plates don't rust together as well..
   / Ford 1510 - what to do for winter storage? #4
Also do what you can to keep mice and other critters out.
I'd lube everything well. Check condition of coolant and top it off.
   / Ford 1510 - what to do for winter storage? #5
I have heard that mice do NOT like moth balls. Maybe put some moth balls under the hood and in the battery compartment.
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
JOHN DEERE 7300 (A53084)
JOHN DEERE 7300...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
Anderson 31ft T/A Flatbed Equipment Trailer (A51691)
Anderson 31ft T/A...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
WEILER S350 SKIDDER (A52707)
WEILER S350...
