John Deere 3140 Fuel Sending Unit Seal Leaking
   / John Deere 3140 Fuel Sending Unit Seal Leaking #1
bigblock76
Little Britain, Ontario
John Deere 2120, John Deere 3140, John Deere 2950, John Deere 7700 Combine, John Deere STX38
Is there a way to snug this up more? I don't see a nut to turn. Not sure how to snug it up if its possible. Fuel is leaking out from behind it though.
   / John Deere 3140 Fuel Sending Unit Seal Leaking #2
Check if piping is loose on that sender ? Do not turn sender by using piping as a handle ! It seals with an O-ring
It's not the piping for sure. Its coming from behind the flange / plate of the sending unit and fuel tank.
If I turn the sending unit will that snug it up?
   / John Deere 3140 Fuel Sending Unit Seal Leaking #4
drain fuel to below sender ...remove sender by turning it anti-clockwise....clean o-ring ...re-install by turning it clockwise till you feel it click in the lock posision about 1/8 turn
Thanks everyone. Simple fix for a big mess it was making
2003 GROVE TMS500E MOBILE TRUCK CRANE (A51406)
2003 GROVE TMS500E...
2005 Nissan Pathfinder SUV (A53424)
2005 Nissan...
2015 Ford Taurus Sedan (A51694)
2015 Ford Taurus...
2016 Chrysler 200 Limited Sedan (A51694)
2016 Chrysler 200...
Bell B30E (A50123)
Bell B30E (A50123)
