How often do you have your septic tank pumped?
   / How often do you have your septic tank pumped? #81
Interesting thread. I'm astounded as to the wide variability in pumping frequency. Generally speaking, it's a "crap shoot." Some pump religiously every 3 or 4 years (election cycles, interesting mnemonic) while others have not pumped for as long as they have owned their homes. The average national cost of septic tank pumping and cleaning is $385. Over a 30-year span, the homeowner pumping every 3 years has invested $3,850 (approximately $10.69 a month). With the cost of some of the more elaborate systems running into the tens of thousands, regularly pumping might be justifiable for some. I'm no expert, but my take-away so far from this thread is that pumping frequency among homeowners is primarily driven by: 1. the wide variability in household composition, 2. system design (including drainfield characteristics and tank size), and 3. local jurisdictional regulations.
   / How often do you have your septic tank pumped? #82
One time after 30 years. Man said it didn't need it then.
How many in your household?
Same question for wagne, turby, and others who may not have indicated household size. My wife and I (plus washing machine) live alone. I've gotten away with not pumping for 10+ years. My stepdaughter moved in for a brief "period" during that time. Despite us asking that she only flush TP, I can tell you with complete certainty that did not happen on at least one occasion. Point being, if she lived with us permanently there's a good chance my drainfield would've failed by now.
   / How often do you have your septic tank pumped? #83
I lived at one place with a 750 gallon septic for 17 years. Three people in household. Never needed pumping. No garbage disposal.
   / How often do you have your septic tank pumped? #84
I tell you what, I sure wish we could have a separate gray water system and I am almost tempted to do something after the fact if I could easily separate out some of the drain lines down in my crawl space. The amount of times my wife runs the washing machine and dishwasher in our household is insane. No reason all that discharge needs to run through the septic tank and drain field.
   / How often do you have your septic tank pumped? #85
Ditto that. I just e-mailed my buddy who is code enforcement officer in next town over to see if he thinks local code allows. I'd call the code office in my own town but once I did that (called Code Enforcement Officer with a construction related question) in a nearby town and later that week I saw that same Code guy in his car just across the road. Coincidence maybe?
   / How often do you have your septic tank pumped? #86
11 bucks a month to keep the crap flowing in the right direction does not seem unreasonable.....we pump our septic every 4 years.
   / How often do you have your septic tank pumped? #88
^^^ Always used an old nylon stocking... does a fantastic job and amazing what accumulates over time.
   / How often do you have your septic tank pumped? #89
About the only way to use a nylon stocking would be to have a laundry sink to drain the washer in to. Since I don't have a sink, the cartridge type is what I have to use.
   / How often do you have your septic tank pumped? #90
Yep... laundry sink next to the washer in the mud room...
2014 Club Car Electric Utility Cart (A51694)
2014 Club Car...
NEW HOLLAND TS6.120 TRACTOR (A51406)
NEW HOLLAND...
2020 CATERPILLAR 299D3 XE SKID STEER (A52705)
2020 CATERPILLAR...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A54313)
2016 INTERNATIONAL...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
