New Holland 7106 Loader lift cylinder rebuild question
   / New Holland 7106 Loader lift cylinder rebuild question #1
speters
SE Michigan
John Deere GX335, Kubota ZD21, New Holland TC21D
I need to have my lift cylinder off from the my New Holland 7106 loader repaired. (It needs to be welded) I removed it from the tractor but am unable to disassemble it. There is a nut on the end but everything spins when I turn it. I looked at the parts diagram online but don't see how to keep it from spinning. The cylinder is part # 86608112. Has anyone taken one of these apart before?
Thanks!
   / New Holland 7106 Loader lift cylinder rebuild question #2
Thanks!
I do not know your specific tractor.
All I find on line is that the specific part number has been discontinued.
If you post some pictures someone like me is much better to be able to give you some advice.
Sometimes there is a large snap ring buried in the crud that holds the end on the cylinder.
These video might be relevant to your cylinder. The second video shows a similar but more complicated snap ring and retainer ring design.
How to Repair Snap Ring Cylinder - YouTube
How to disassemble a Motus Hydraulic Cylinder - YouTube
The third video is a different design and requires a special removal ring.
How to Assemble a Wire Ring Cylinder - Monarch Industries Ltd. - YouTube
Another design, another video
Locking Pin Hydraulic Cylinder - YouTube
Dave M7040
Dave M7040
Thanks Dave!
I found a thread on another tractor website/forum that explained it. The cylinder has to be fully extended and pressurized. That locks the cylinder head in place so the nut can be removed. Once the nut was off I just pushed that cylinder head back in revealing the circlip...removed that and walah! I used shop air to pressurize my cylinder for this. Forums like this are priceless. Thanks again for the suggestions!
Scott
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2012 NOV ROLLIGON CEMENT PUMP TRAILER (A53843)
2012 NOV ROLLIGON...
2003 FORD F350 XL SUPER DUTY DUMP TRUCK (A51406)
2003 FORD F350 XL...
2025 Icon Electric Cart (A51694)
2025 Icon Electric...
2007 KONECRANE SMV25-1200B STRAIGHT MAST FORKLIFT (A51406)
2007 KONECRANE...
