Updated TV Antenna Thoughts
   / Updated TV Antenna Thoughts #41
I changed a 6' coax cable on my antenna, from preamp to a new balun because I couldn't get the new boot over the F connector. Since I already have several feet of older coax, I'll just get some new F connectors and for the heck of it the tools to put new Betts Snap-N-Seal on, so first I look for how to use these tools on youtube and the next thing I know is, QUAD SHIELD RG6, so now I guess coax is not coax, got to have the all new improved quad shield to cut down interference and get better reception.
Why does things always have to change, they've must of been making coax cable now for 30+ years, takes this long to make the right cable...........Just thinking out loud whether or not to change all my 100+ ft of coax cable to the state of the art quad shield, just so they can come out with something better in another 5 years.
   / Updated TV Antenna Thoughts #42
Interesting that Fox is your most difficult to pick up. When I tested the first time I did not get my Fox6 Birmingham, and no Fox20 Montgomery. I had to aim the antenna just right to get it. Still have issues with PBS, which is ok.
Now I have my antenna in its final location, aim it just right and I have Fox6 Bham, NBC Bham, CBS from Bham and Montgomery, and three ABCs. Plus the other channels that go along with them, and PBS seems ok in new location.
Why did I use this location? Because this is where there was a splice in the Direct TV cable run into the house. I checked and they ran RG6 all the way so this saved my having to purchase cable and make the crazy run into the house. I am a happy camper now
You have quite the antenna there lakngulf.
You didn't mention the type of installation you have or the antenna model or type. If you bought one of those flat wave antennas, they are notoriously poor for VHF reception in any type of fringe setting. If you bought a small Yagi style, (RCA-ANT751) that should work, but they don't have a lot of gain. KTBC in Austin doesn't broadcast with a lot of power which makes things worse.
I have this one , but I tried to mount it about 8" below the uhf small antenna (didn't want to mess up what I already had working). Would the proximity have messed things up?
Amazon.com: RCA Compact Outdoor Yagi HDTV Antenna with 7 Mile Range: Electronics
   / Updated TV Antenna Thoughts #43
Since i trimmed a tree and broke my antenna, I just bought the wineguard fl6550a, supposed to have 60+ mile range. Came today but didnt try it yet.
   / Updated TV Antenna Thoughts #45
Hard to beat a good Yagi.
Generally you want to mount things 1/2 wavelength away from each other(VHF is ~2 meters, UHF is 70cm) so 3.5ft distance should be just fine. You can mount closer, it's just less ideal.
   / Updated TV Antenna Thoughts #46
Keep in mind that distance is going to depend on if you have a clear line of sight and how high up you can get that antenna. I've seen VHF on the amateur radio side do 80+ miles but that's with repeaters that are up on some pretty high mountains.
   / Updated TV Antenna Thoughts #47
Quad shield is not new? I’ve been using it for years.
   / Updated TV Antenna Thoughts #48
We found that with the advent of digital TV the system became more susceptible to interference from such things as motors turning on and off (refrigerator/freezer) and other switches being operated, resulted in a brief but annoying period of pixelation, we changed our dual shield to quad and the problem went away.
Screw and saddle in line fittings also had to go and be replaced with F connect.
A compromise is tri shield, marginally cheaper.
You can still buy that horrible RG59 airspace single shield here but why would you.
As stated though, if your system is working fine it doesn't need fixing.
I haven't been to USA for a few years (used to be a regular visitor to NY, Boston and DEnver) so I'm not sure where you stand with digital but we switched over ten years ago.
   / Updated TV Antenna Thoughts #49
Since digital we have not had TV reception. I gave up trying to figure it out. I hate to spend money without being certain. I don't want another monthly bill, so cable and satellite are out.
Ok, my next step is to make the mast pipe more rigid. It is strapped well to the telephone pole, but does move a bit with the wind. There is a particular angle that brings in some stations better. What can I do to hold it steady? I had trouble trying to drill a hole thru the pipe, or a bolt thru pipe and pole would work. Any ideas?
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
Generac Generator (A51691)
Generac Generator...
2014 FORUM HORIZONTAL 3 PHASE SEPARATOR (A52472)
2014 FORUM...
2016 LOAD MAX 24 GOOSENECK (A52472)
2016 LOAD MAX 24...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
