buickanddeere
Super Member
I looked at things with that zipcode and it does favor Birmingham. The only advantage with the Winegard HD8400P is that it would be better for FM radio and WVUA channel 6 if you want to receive that. Otherwise, I would still stick with the HD769xP models. The HD8400P is also a much wider antenna.
The Stacker is simply a VHF-High antenna and a UHF antenna mounted together. It will have the same channel 6 problem as above. If size is an issue, the HD7694P is nearly the same size and offers almost the same gains as the Stacker, and far less mounting and weather problems.
The biggest issue is going to be what kind of terrain do you have to deal with and how high can you get the antenna. Also, the longer the antenna boom and the higher the gain, the more directional the antenna will become.
The channel 7-51 antenna have the advantage of not receiving as much of the FM radio broadcast band. The FM radio signal causes tuner overload and intermode interference . The absence of the channel 2-6 elements makes the antenna much smaller and less susceptible to wind and ice damage.
As previously stated, a good antenna mounted amplifier is vital.
