Where is my aux light (work light) connectors??? (BX 23s)
   / Where is my aux light (work light) connectors??? (BX 23s) #1
Old Red
Western Kentucky
Kubota M6800 HDC
Cannot find these little buggars anywhere! I know someone can point me to them quickly. I also see no reference to them in the manual but do see the fuse for "work lights". Anyone know where they are on the new 80 series BX?????
   / Where is my aux light (work light) connectors??? (BX 23s) #2
Used to be under the left rear fender on other Kubota models.
   / Where is my aux light (work light) connectors??? (BX 23s) #3
Follow the wire harness for your rear flashers, should be in the same wiring harness.
Might be taped up where you can see them, but the wiring is there for it.
   / Where is my aux light (work light) connectors??? (BX 23s) #4
Mine were under the passenger side rear fender. They were in the wire harness for the rear flashers.
   / Where is my aux light (work light) connectors??? (BX 23s) #5
Thanks everyone. Here is what I ended up doing for now. Not sure I will keep it this way or not. I basically purchased a wiring harness that ties directly to your battery. It is fused and has a relay with a switch an connectors for the lights. I think they make it as dummy proof as they can. I really wanted to go inside the roll bar which is how I think Kubota engineered the new BX machines. Anyway, this all got started this weekend feeding my brush pile I finally decided to burn.
2017-12-06 17.44.50.jpg 2017-12-06 17.44.28.jpg2017-12-02 16.21.32.jpg2017-12-03 12.45.25.jpg
METAL SHOP TABLE W/CONTENTS (A55745)
METAL SHOP TABLE...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
MINI EXCAVATOR BUCKET 32 (A55745)
MINI EXCAVATOR...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A54814)
2003 Pierce Tilt...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
HIGH END ELECTRIC GOLF CART (A55745)
HIGH END ELECTRIC...
