Question on the Kubota B-2650
   / Question on the Kubota B-2650 #1
jodebg
New Hartford, CT
Kubota B-2650
My prior tractor was a B7800 with the 3ph quarter inching valve.
When I shut the tractor off and moved the fel control lever around to
eliminate hydr pressure, both the fel and 3ph responded.
With the B2650, it seems like only the fel system pressure is relieved.
Am I doing something wrong? Is there a way to relieve the 3ph pressure, as well?
   / Question on the Kubota B-2650 #2
I do believe that lowering the TPH relieves any pressure from it.
   / Question on the Kubota B-2650 #3
Why the concern about relieving pressure?
Interesting note on the behavior of your B7800. I've had one for over 7 years now and don't recall the 3pt and FEL being tied together like you're describing. When I park I generally drop the loader bucket and then lower the 3pt (almost always have an implement attached), so maybe I'm missing this happening due to this sequence? For sure, though, it doesn't happen with the tractor running.
   / Question on the Kubota B-2650 #4
Something must have been wonky with your old tractor. Relieving pressure in the FEL circuit shouldn't de-pressure the cylinders holding up the 3 pt. Having something on the back dropping when you moved the FEL joystick would be pretty unsafe, wouldn't it?
   / Question on the Kubota B-2650 #5
Use the FEL stick to relieve the FEL and the 3 pt lever to relieve the 3 pt.....as I understand it.
2021 Bobcat S64 Skidloader (RIDE AND DRIVE) (A50775)
2021 Bobcat S64...
2025 MAMMOTH SB-2 2025 SAND BOX TRAILER (A56129)
2025 MAMMOTH SB-2...
UNUSED Wheeled Dump Hopper (A47477)
UNUSED Wheeled...
2010 DODGE RAM 2500 FLATBED TRUCK (A51247)
2010 DODGE RAM...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
2013 Chevrolet Traverse AWD SUV (A53424)
2013 Chevrolet...
