Plywood for concrete forms
   / Plywood for concrete forms #12
I guess there are using the fancy term of hydrating for water...which we all know concrete has in it.
Hydrating is to always put water into something. Concrete "hydrates" once at the initial stage, then there is no more hydrating.
   / Plywood for concrete forms #13
Forms are generally removed so they can be reused...the plywood is usually coated with an oil or release agent...
As an example of moisture permeating wood in direct contact with poured concrete...just look at the bearing surfaces of fabricated roof trusses...there will always be a "tin tab" at the bearing points to separate the wood from the conc. even thought the top of the poured beam (lintel) is protected from the elements...
IMO it will take years for moisture to exit through the plywood if left in contact with the pour...a moisture barrier (plastic/rubber sheeting etc.) may be a viable solution...
   / Plywood for concrete forms #14
No, it's a chemical reaction between the Portland and the lime. Water just keeps the chemical reaction, Cure, to a slower rate. There is no such thing as hydrating in concrete...
Here is one of the chemical formulas of the hydration of cement during the creation of concrete. You'll see that the water becomes part of the molecular structure of the polymer
2 Ca2SiO4 + 5 H2O---> 3 CaO.2SiO2.4H2O + Ca(OH)2 + 58.6 kJ
Concrete: Scientific Principles
In short, you just need to be quite, cause you don't seem to understand chemistry
   / Plywood for concrete forms #15
Careful Rock knocker, you have mixed apples with your oranges and may get called out for it. :)
   / Plywood for concrete forms #16
So yea...portland, lime and water.
What point here are you making?
   / Plywood for concrete forms #18
You were the first person to use the word "cement". The nitpickers on this thread may point that out to you in a negative way!!! :)
   / Plywood for concrete forms #20
I remember a wall my dad and I built about fifty years ago, formed with plywood and lots of 2x4 bracing and steel tie rods, we thought. Well the whole thing held together but the plywood bulged out between the bracing so much that when the calculated volume of cement was poured the wall was about 2 feet shorter than planned.
I have noticed that the plywood that the concrete contractors around here use is at least 3/4", and appears to be faced with some sort of hard smooth laminate. It also looks to be void free with a lot more plys than ordinary lumber yard fare. In other words a lot more substantial than what my dad and I were using.
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2021 KENWORTH T680...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2014 VOLVO VNL (A55745)
2014 VOLVO VNL...
CAT D5G LGP DOZER (A58214)
CAT D5G LGP DOZER...
2025 40ft 10-Door Shipping Container (A59228)
2025 40ft 10-Door...
