RSKY
- Joined
- Oct 5, 2003
- Messages
- 2,486
- Tractor
- Kioti CK20S
Now I'm sure someone smarter than me can chime in but I've seen repeated thing showing that 556 actually will travel through far-less barrier and air after the barrier than even a simple 9mm. I would be interested in seeing more things on YouTube and all where they see what the bullet does after it's gone through at two layers of drywall or something I see a lot where it shows how many things that can punch through but not what happens 10 feet after
5.56, 12 gauge, and 9mm vs drywall in slow motion - YouTube
There you go, ten walls and they both penetrate nine.
My 'home defense' shotgun has low recoil 00 or #4 buckshot stored on the side for this reason. Those rounds are for use outside if I ever have to dispatch another skunk or finally get a shot at one of the coyotes sniffing around. On the stock I have the slowest, lightest loaded #4 shot I could find as the actual 'home defense' load. At ten feet or less even the plastic wadding is gonna hurt and the lead will be so close it will penetrate. Hopefully the lighter shot will have a harder time penetrating drywall.
Here is a link I highly recommend anybody with a shotgun for defensive use look at. Actually, anybody that uses a shotgun for anything other than bird hunting could learn something from this. They test everything from #8 birdshot to 00 Buck to different types of shotgun slugs in ballistic gelatin. I do NOT want to ever be shot with a high powered slug. Heck I don't want to be shot with a low powered slug. Or be shot with bird shot. I really don't want to be shot with anything but the destruction caused by some of those slugs is just scary.
Shotgun Penetration With Various Rounds - The Truth About Guns
RSKY
