Gravity fed transfer tank?
   / Gravity fed transfer tank? #11
Towing something without a suspension system at a safe highway speed might be a problem.
Would be pretty dumb to tow this on a highway. I'll be going 30mph tops, 2.5 miles on paved roads and around 2.5 miles on dirt roads.
   / Gravity fed transfer tank? #13
I have a 50 gallon aluminium fuel tank off a semi I'd planned on making into a gravity feed fuel tank. I have an inch hose for it. It should flow pretty decent.
Provided it is well vented; the regular fuel cap vent won't let in enough air for rapid feeding.
   / Gravity fed transfer tank? #14
I have never towed a farm wagon (no suspension) on the highway but with my tractor, top speed is 15 mph and I still have to slow down for dips, pavement repairs, and intersection humps to keep all the wheels on the ground.
   / Gravity fed transfer tank? #15
I would bet the hose running down the front of the tank had a pump on it as it appears it is connected to a draw pipe up top. You could get a good 12V fill rite pump and be all set.
Yeah I got to thinking about it after you mentioned it, the dirt roads are pretty bumpy. We'll have to see how that works out.
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2008 JOHN DEERE 672D MOTOR GRADER (A52705)
2008 JOHN DEERE...
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
