4300 vertical exhaust hood cut out template?
   / 4300 vertical exhaust hood cut out template? #1
larboc
hancock, MI
John Deere 4300, Deere 455, Ariens GT17, Cub Cadet O, Wheelhorse 50
Anyone have a copy of the template? I bought the stack, bracket, and bolt individually from an online deere dealer but it didn't come with instructions on how to cut out the hood. The hood has two lines on it but nothing for the radius.
Never found a part number for the "kit" for the 4300, only for the 4x10's which is different.
   / 4300 vertical exhaust hood cut out template? #3
Twice now I've just eyeballed it. Turned out pretty good both times.
   / 4300 vertical exhaust hood cut out template? #4
CUTTING 4300 HOOD
this was my install
   / 4300 vertical exhaust hood cut out template? #5
The second time I did mine I used a hole saw. I centered the hole on the exhaust pipe and drilled through. I used a hack saw to trim the edges similar to the template and used a flap wheel on a die grinder to do the blending.
With the reputation of these hoods and as much loader work as I do I'm sure I'll have an opportunity to do it again at some point as well.
   / 4300 vertical exhaust hood cut out template? #9
Just curious why you are doing this? I like the lower exhaust on the newer tractors. I have some old ford's with the vertical, and they seem to get banged up in the woods clearing brush.
I see you are in Hancock, so I suspect it's the 12" of snow you get everyday!!! I've been up there several times over the last year or so for work, very nice area.
   / 4300 vertical exhaust hood cut out template? #10
I had a lower exhaust on my 4410 for years. I set up a 59 snowblower for the front end. You couldn't get away from the exhaust smell. So I went with a vertical exhaust and I won't go back. Now it's very seldom that I have to put up with the exhaust smell.
And yes you do have to watch the exhaust pipe in the bush. It's a small price to pay!
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
1pallet of miscellaneous items (A53117)
1pallet of...
2004 Ditch Witch RT70M Ride On Trencher (A53117)
2004 Ditch Witch...
Hydraulic 50 mm pin thumb (A52384)
Hydraulic 50 mm...
CONTACT INFO (A53084)
