Iseki TX1510 hydraulic suction filter/o ring replacement
   / Iseki TX1510 hydraulic suction filter/o ring replacement
Hi can you advise where the drain plug(s) are located?
   / Iseki TX1510 hydraulic suction filter/o ring replacement #12
Drain plugs for the transmission are near the bottom of the output shaft housings, facing towards each other just as the housings start to go vertical (the plugs are horizontal if I remember correctly.) I think they are a 3/8" NPT plug, maybe 1/2". The drain plugs are in a similar location on each of the front final drive housings. I don't think the fronts have a plug for how far you're supposed to fill it to. You just add a fixed amount of oil which I'd have to look up the amount for. Maybe a couple hundred milliliters. The main transmission has the dipstick of course.
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
2017 Chevrolet Tahoe SUV (A56859)
2017 Chevrolet...
2013 John Deere 650K Crawler Tractor Dozer (A56857)
2013 John Deere...
2016 GENIE S-65 TELESCOPIC BOOM LIFT (A52709)
2016 GENIE S-65...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
