Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #5,141
...or stacking! :laughing:
That is just the long term wood lot. By the time I burn firewood, it has been cut for at least two years. Once in the spring, and once in the fall I top off one half of my wood shed which is located 10 feet outside my walkout basement. One half of the wood shed lasts me pretty close to a year, so I refill one half in the spring and burn it the next winter, and the other half I try to top off in the fall from summer burning. I often can not get through the "summer" half of the wood shed though.
Firewood is usually in here close to a year before it gets burned.
As you can see it is a family affair. We all love working outside together.
From there, my firewood (now seasoned to approximately 8%) or less goes into my state of the art, Froling Turbo 3000 indoor, wood gasification boiler. I use it to heat my home, and domestic hot water year round. I have an 800 gallon storage tank in my basement with close to 200k btu of heating coils inside it. One coil is dedicated to domestic hot water. In the summer, I burn approximately 100 pounds of wood (in one, weekly burn) to produce all of our hot water needs for the week. Most winter days I burn approximately 80-100 bounds a day. In the last week or so, I have been pushing close to 160-180 pounds a day. It is -14 outside today, but my house is 72.
I have not bought oil for my oil furnace since 2011.
Here is a pic of my wood boiler.
I did say don't get me started...
   / Tractors and wood! Show your pics #5,142
Above I posted picts of loading and milling this blk. cherry log,
and I mentioned that the tree it came from, had three logs in it and here's the next log that tree produced, it's 8' 6" long,
So I got started by opening it up and turning it, to see what I had,
and it didn't disappoint!
and where there were defects, it made for some nice figure!
I ended up with a pretty good tally of 5/4 lumber on this log too!
So, now it's time to go get that third log I mentioned, milled too!
SR
   / Tractors and wood! Show your pics #5,144
My Grandfather was a man of few words and not easily impressed...
That said, as a young child I remember the first time I did impress him... and it was stacking wood in the crib on the farm and all these years later I still remember it.
   / Tractors and wood! Show your pics #5,145
Sweet. I have a gassification / storage system that is an HS Tarm. I put my storage outside, under ground, so I lose heat that way. It's about 1600 gallons though. No pictures handy, but 3 zones of radiant floor and home-run domestic water makes it look like command central. Works great though.
   / Tractors and wood! Show your pics #5,146
ae, tell me about your underground storage! I too run a gasser but no room for any (conventional) storage. I was thinking about building a vault or getting a septic tank to house the conventional insulated LP tanks just outside of my boiler room.
   / Tractors and wood! Show your pics #5,147
ae, tell me about your underground storage!.
Where I used to work, there were underground fuel tanks that had to come out. One was 2,000 gal, by my volume calcs. I cut a hatch, put in coils, welded bungs, etc. Made the hatch bolt-able and had a spray foam guy spray it with 6ish inches of foam. Then I buried it outside my basement wall.
Between it and my septic tank, snow doesn't stay there. But, I don't get the residual heat in the summer, since it's my domestic hot water as well.
   / Tractors and wood! Show your pics #5,148
Impressive. I am humbled. Very nice.
   / Tractors and wood! Show your pics #5,149
SR
That wood sure is impressive. Thanks for posting. I sure wish we had your hardwoods out here in the West.
CASE 6591 T/A PORTABLE POWER UNIT (A51247)
CASE 6591 T/A...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2021 Allmand Bros...
UNUSED 70PCS Black Metal Roof Panels (A53117)
UNUSED 70PCS Black...
2012 WESTERN STAR 4900 (A53843)
2012 WESTERN STAR...
1839 (A51248)
1839 (A51248)
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
