Need Help!! battery Kubota BX
   / Need Help!! battery Kubota BX #1
KTucke
Member
Connecticut
Kubota BX 25D
I took out the battery yesterday to put it on the trickle charger. When I put it back it's a real tight space so had to use socket with extender. It sparked as I hit metal with extender. I dropped it while it was still connected and it fried battery and ground wire.
Don't see anything else fried but ground wire. Could I have fried the electronics?
Don't want to wait until dealer opens on Tuesday. Where can I get another battery on a Sunday New Years eve? Also any 12v battery that fits in the compartment with as many CCA's as possible? Nothing in the manual
How the **** do you tighten the positive connector without using a socket with extender and risk doing the same freakin thing?
Any help would be greatly appreciated.
   / Need Help!! battery Kubota BX #2
....connected and it fried battery and ground wire
Doubtful you fried the electronics as you really didn't go thru any.
Yup, Physical size, electrical size as well as orientation of the the terminals.
How the **** do you tighten the positive connector....
Either tighten the positive first (which is the proper way to do it so you don't end up shorting something out, ground off first on last) or if there's some physical reason you have to do the negative first, wrap the entension and sockets with a couple of layers of tape. not the recommended way but sometimes you gotta do what you have to...................Mike
   / Need Help!! battery Kubota BX #3
positive wire on first then ground when installing , ground off first then positive when removing
   / Need Help!! battery Kubota BX #4
Pretty sure when I replaced mine last year on my BX24 I got the same matching battery number at Wally World.
Also, both + and - leads on mine pull out far enough I attach the leads on the platform floor and then push the attached battery into its spot and fasten it with the rubber strap.
And what other comments say for order of attachment.
Thanks for the quick replies!! But the batteries a real funky size. Looked on Tractor Supply website and it wasn't very helpful. Just drive around to autoparts stores with dimensions? Also I should replace the ground as all the rubber is burnt off. It's really long where would I get a ground that long? Again tractor supply no help
Missed that last post. I'll try Walmart for battery but what about ground wire?
   / Need Help!! battery Kubota BX #7
Any auto parts store will have a ground wire
   / Need Help!! battery Kubota BX #8
Walmart will have ground wires too, usually by the auto batteries.
Advanced autoparts had everything. Hooked everything up. Started right up. Love this forum.. Thanks for the help!!
   / Need Help!! battery Kubota BX #10
Next time if you order online and pick up at store u can get 20% or 25% off just google Advanced auto parts coupons
2022 Coras Predator Steel End Dump Trailer (A56438)
2022 Coras...
New/Unused Quick Attach Pallet Forks (A57453)
New/Unused Quick...
(APPROX. 20) 4' X...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2022 Behnke Trailer (A55973)
2022 Behnke...
Service Truck (A59230)
