Need Help!! battery Kubota BX
   / Need Help!! battery Kubota BX #13
Yes, the BX25 also takes the Group 26R battery with 535 CCA (AKA524F/22FA).
I put a AutoCraft Silver Battery, Group Size 26R, 575 CCA in my BX2200. Had it for a few years now. Works great!
   / Need Help!! battery Kubota BX #14
I got a replacement battery for my BX-25 at Nappa. They might still be open at this hour. They have good hours.
   / Need Help!! battery Kubota BX #15
may i ask why bother remove and put battery on a tender? if needed just slide battery out and put on floorboard and tend battery from there. leave everything hooked up.
   / Need Help!! battery Kubota BX #17
I have something similar. Not a trickle charger, but a smart low-amperage maintainer. Got one on everything with a battery - with the pigtail permanently installed. Works a treat. Sealed unit, no water/weather issues.
22-15-DL-WH
Z.
   / Need Help!! battery Kubota BX #18
i put the same battery that was on my 2004 bx 1830 and the old battery was still good but didnt trust it and was cheeper at the dealer than the other place and every month i put a low battery charger and the battery is full load all the time and will lass you for a long time
2013 Ford Fusion SE Sedan (A56859)
2013 Ford Fusion...
20ft Jumper Cables (A57454)
20ft Jumper Cables...
2017 Dodge Charger Sedan (A56859)
2017 Dodge Charger...
7ft Workbench (A57454)
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A56859)
2014 Glasstream...
2019 RAM 5500 Bucket Truck with Versalift VST47 Boom - Cummins Diesel - 4X4 - Automatic (A56438)
2019 RAM 5500...
