New owner 4720ch! questions on top-n-tilt kit
   / New owner 4720ch! questions on top-n-tilt kit #11
After a good long time of lurking and researching and kicking tires at dealers I finally purchased myself a tractor! It was a hard decision between the 4720ch and the 4225ch. Figured I would stick with the tested engine than the new one and end up with more hp for about the same price.
In any case, I am very interested in getting a top-n-tilt kit. Does anyone have a kit they have been pleased with? Where did you get it?
Hey madpuma.
Did you make a move on a top and tilt?
Hey madpuma.
I got a hydraulic top made by my tractor shop, which is amazing. Never got the tilt tho and thinking about doing that still.
   / New owner 4720ch! questions on top-n-tilt kit #13
I have both top & tilt. Tilt is very jerky. I don't have enough experience with hydraulics, but would guess that an adjustable bypass would be a good idea to dial it in. Also, using the tilt will press on the hydraulics, quick attach, and other components. Not necessarily a bad but try to visualize that vs the convenience of tilting from the cab.
   / New owner 4720ch! questions on top-n-tilt kit #14
Try some flow restrictors, I typically recommend .030 orifice size for 2" cylinders, .045 for 2 1/2" cylinders and .060 for 3" cylinders.
You may find that you would benefit from these being on your top link also. ;)
   / New owner 4720ch! questions on top-n-tilt kit #15
Excellent suggestion. I will look into this. Top link is OK. Perhaps this is because the tilt remote has as center detent or ?... All I know is the tilt is hard to center.
BTW, I also have the aux front bypass option for a grapple, blade angle, etc. highly recommended. While the loader controls hardly compare to a skidsteer or other proper equipment, it is much nicer than the clumsy loader control on a JD or Kubota.
2022 Polaris General 1000XP UTV (A50514)
2022 Polaris...
CATERPILLAR 305CR EXCAVATOR (A51242)
CATERPILLAR 305CR...
2010 Nissan Rogue SUV (A50324)
2010 Nissan Rogue...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
UNUSED MOWERKING QUICK ATTACH BOX BROOM (A51244)
UNUSED MOWERKING...
UNUSED MOWERKING SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED MOWERKING...
