massey 1540 hydraulic leak retrun pipe
   / massey 1540 hydraulic leak retrun pipe #1
case310350
There is a hydraulic leak on the pipe coming out of the filter assembly and going forward to engine. I see there is a rubber hose connecting the two pipes but that connection is ok.
the problem is I have the loader brackets and skid plate blocking my view and cannot determine where the leak is. further more removing the skid plate, looks like I have to remove the loader frame, lots of work especially in the cold weather. Looking for advice.
   / massey 1540 hydraulic leak retrun pipe #2
Give it a really good bath, run it a few minutes and then use an extendable mirror and flash light to locate your leak..... and yes, it is no fun washing a tractor when its cold outside.
Its coming from the transmission breather tube
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
2006 Ford F-750 Fuel and Lube Truck (A56858)
2006 Ford F-750...
UNUSED FUTURE 13' 200 AMP JUMPER CABLES (A58376)
UNUSED FUTURE 13'...
2015 Ford F-550 Crew Cab Godwin 184U Mason Dump Truck (A56858)
2015 Ford F-550...
2015 AMERITRAIL MANIFOLD TRAILER (A58216)
2015 AMERITRAIL...
Year: 2019 Make: Ford Model: F-350 Vehicle Type: Pickup Truck Mileage: 24,981 Plate: Body Type: 4 (A59230)
Year: 2019 Make...
