colt starter
Hi. I am new to this site and I'd appreciate any help you may have here. My little backhoe loader has an issue. two days ago i went to do some work and the loader wouldn't go up or down. If I tilt slightly I can get it to go up and down slowly if I multifunction. The engine is working hard, and I can tell the hydraulic pump is working overtime. Fluid is not flowing but sounds like it's dead heading pressure. I have had a leaking ram on the loader, and didn't watch the fluid level like I should have. When I checked it it was not showing on the dipstick. I had left the tractor for about an hour after running it when I checked the fluid level. I added about 2 gallons. It then was then showing in the minimum level area. This morning I checked it and it shows full. Fluid must have settled in some. I purchased the tractor with 1242 hrs. It now has 1550 hrs. I changed the engine oil and filter, but have not changed out the hydraulic fluid. The dealer had done that prior to my owning it. the hydraulic oil looks good on the dipstick. Clean, if that matters.
Any help is greatly appreciated. If there is a previous thread that addresses this please direct me. thanks.
