I knew I shouldn't have said anything,,,,
   / I knew I shouldn't have said anything,,,, #1
japody
Richmond & Boydton VA
Ford 4000 & 5000, New Holland TN65, Mahindrda 2516
On another thread about frost proof faucets, I extoled the virtues of a Mirafount cattle waterer. I mentioned how mine has never frozen, even in the coldest weather. I guess I jinxed my luck. Checked on one of the waterers yesterday and it was frozen solid. I guess I'll have to wait for the spring thaw before I can see what went wrong. Has anyone ever had one of these freeze up on them? Any suggestions? Here's a link to the waterer:
MiraFount 335 - Four-Hole 33 Gallons – Miraco Waterers
   / I knew I shouldn't have said anything,,,, #2
I see you’re in Virginia?
Do you have a heater with it?
No heater. They work off an earth tube, 12 inches wide and sunken 4 feet in the ground. Our frost line here is less than 2 feet.
   / I knew I shouldn't have said anything,,,, #4
Obviously the rate of heat coming from the earth could not keep up with the heat the water lost to atmosphere. In other words it got too cold.
   / I knew I shouldn't have said anything,,,, #5
It would seem that a lot of folks are having many & varied problems with the recent cold wave.
UNUSED LANDHONOR LHR-AIW1-1" AIR IMPACT WRENCH (A54757)
UNUSED LANDHONOR...
2015 Ford Transit Cargo Van (A55852)
2015 Ford Transit...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A55788)
2016 Big Tex 14ft...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A54814)
2003 Pierce Tilt...
UNUSED 70PCS Black Metal Roof Panels (A53117)
UNUSED 70PCS Black...
UNUSED (1) 5200# DROP AXLE W/ BRAKES (A54756)
UNUSED (1) 5200#...
