hard start under 40* thoughts?
   / hard start under 40* thoughts? #11
Jerry, how so on breaking the rings? The stuff I bought says it has lubricants in it to prevent damage to cylinders.
I'll check the spark as soon as I can get some help, I can't reach the start button and see the plug wire from a single spot...lol
Thank you for your input.
It the shock load as the starting fluid detonates in the cylinder(s). It's not a lubrication issue.
OK, did not know this, I won't use it then. Thanks.
I'm beginning to think it has low compression as it does have something going on with blue smoke out the breather to the point where they installed a heavy hose to the rear of the tractor for it instead of recycling it back to the air cleaner.
Hopefully it will start later in the week as Temps get up to 40 or so.
It was 35 here today mid day, hooked the jumpers from my truck to it and got it fired up. I believe it's a fuel issue, I noticed a small patch of yellow snow under the carburetor area. It took some crankin and some finesse to get her going but once running it ran great. I moved some snow and some firewood with it then parked it out back, it will probably be there till spring :(
Maybe a new Zenith carb?
   / hard start under 40* thoughts? #15
Good luck with her, the carb isn't to bad to rebuild after a good soaking, have you pulled the sediment bowl and checked the screen in it. Some of those engines take a lot of choke.
LouNY, I haven't done anything yet. I intend to take the loader off for paint this spring so getting at the important stuff will be easier, the points, cap and rotor and the carb.
   / hard start under 40* thoughts? #17
Sounds good, enjoy the temps the next couple of days and we will have to see how the ice and freezing rain ends up.
I see you're just over the hill from me, nice knowing someone is close by, we'll have to get together someday and have a hot chocolate.
I hope the heck we don't get any freezing rain, don't need that. I may have to stuff the tractor into the garage, at least i can light a fire and get it warmed up, if my firewood get's too icey it will be a giant PIA for me.
Well I solved my problem today, loaded that &%?#@ on a trailer and sent it packin' . Now I'm on the hunt for a 30ish hp 4x4 tractor.😎
   / hard start under 40* thoughts? #20
Well I solved my problem today, loaded that &%?#@ on a trailer and sent it packin' . Now I'm on the hunt for a 30ish hp 4x4 tractor.��
Swing by JC Tractors down in Hoosic Falls, he seems pretty decent for a dealer, new and used.
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
New Holland TN65S (A50123)
New Holland TN65S...
Billy Goat Blower Paint Dryer, 6.5 Briggs (A52384)
Billy Goat Blower...
250 GALLON FUEL TANK (A51247)
250 GALLON FUEL...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
1320 Ford HST, 4wd Tractor (A52384)
1320 Ford HST, 4wd...
