Talk me out of a Kioti CK3510SE HC
   / Talk me out of a Kioti CK3510SE HC #31
I'm not really up to date on the newer models.
But my (2001) Kioti DK 35 is 17 years old now with 2100 hours and I've really been happy with it.
Its been good, still runs and operates like new.
Forgot to mention fit and finish.
I still feel the fit and finish on my DK 35 is as good as any tractor brand I have looked at over the years.
   / Talk me out of a Kioti CK3510SE HC #32
I think the title kind of says it all. With a lot of homework, a lot of dealer trips, my own fair share of analysis paralysis, I've finally broken through to what seems like a winner, the Kioti CK3510SE HC. It will do what I need, it fits my tall, fat stature, and it fits my budget.
That said however the proof is often in the pudding and the real phase of discovery is in ownership and while I'm sure I'll discover something less than perfect no matter what I buy, I'd hate to walk into something nasty that I could have discovered ahead of time if I looked just that little bit harder or longer. I'm still open to an alternative if it means avoiding some pitfall.
Obviously I'm searching this model, as well as potential typo variations, into Google and soaking up all I can. Any of you have anything to share that hasn't made it to the internet yet? Spill the beans!
As always, thanks for reading. :drink:
I'm surprised that nobody has mentioned this yet. When you get it, don't forget that we like pictures. Lots of pictures.
Well since this community completely failed me, it should be delivered tomorrow, so I'll see what I can do. :thumbsup:
   / Talk me out of a Kioti CK3510SE HC #34
Looking forward to seeing your decision. I compared the same two tractors you mentioned for months before I made my move, it wasnt easy... but like the others have said, either one of these machines will be great.
   / Talk me out of a Kioti CK3510SE HC #35
Oh you're evil.
I don't know, I'll have to ask the dealer but it's looking like the price difference is about $2k and that gets you 2.5pto horsepower. As much as I would never regret another couple horse when I think about the opportunity cost of that $2k I'm thinking I can likely find more value putting it somewhere else like an implement or maybe even a better seat for someone over 300lbs. I'm not adverse to spending the money, I just want to put it to the best use.
You're still evil though, I gotta think about that. One perk is the dealer doesn't have one so it would be ordered factory fresh vs. on-the-lot-for-3-months fresh.
I stopped reading at this post so its possible someone has already covered this. I am in NY and you are in TX so my experience may not apply. That out of the way, 2.5pto HP in this range might make the difference between having to go with 5' instead of 6' implements. If you are buying all new implements it probably doesn't matter. If you are in a position to buy used when good deals come along at least around here 6' implements have significantly more availability. That leads to better selection and more importantly better prices, to the point you could probably get that $2k back in savings, or at least most of it.
Thanks for the feedback. I did seriously consider that and decided for my purposes the PTO HP isn't a factor for me nor will I need a breadth of implements (famous last words?).
I'm looking forward to seeing it too!! :licking:
   / Talk me out of a Kioti CK3510SE HC #37
You wanted to be talked out of it on January 10th and purchased it on the 11th.... :laughing:
Oh wow, really? It felt like an age!
   / Talk me out of a Kioti CK3510SE HC #39
I own a Kioti, 2006 CK25. Beast for ground engagement. Great fit/finish. As good any except in one area: paint thickness. My JD's paint is many times thicker and tougher than the CKs. Paint is nice on the CK. Just not very thick.
Extra HP: Only if running implements that need it or if you get more loader capacity with it.
I see it's a done deal anyway. Congrats and enjoy.
Thanks for the feedback. Yeah that was the advice I'd seen repeatedly so I took it.
Thanks!
2014 Kawasaki Mule 600 Utility Dump Cart (A55973)
2014 Kawasaki Mule...
2016 Ford F-150 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
72" HYD QUICK ATTACH GRAPPLE (A51406)
72" HYD QUICK...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
