View attachment 535403:laughing:
OK, I'll admit to never operating anything set up like above photo but, I have to question if the operator can actually see what the heck he/she is doing up front? Doesn't seem too safe to me.
All I use is a walk behind snow blower for sidewals and a blade on the front of my tractor for my and my neighbors driveways. Have considered a front mounted snow blower for the front but, I just can't justify it with the limited amount of snow we get in central KY. YMMV.
Rams :drink:
Its at a dealer. I think they left it like that to keep it all together
Yeah, I get that but................. I don't see it as a safe and viable option to do the job. I suppose it depends on how much snow one gets. If I got that much snow, it's time to move. Snow is a four letter word ya know.
Rams
Ray_66v,
Not sure how much backhoe experience you have? I have a ten ft Long brand 3 point backhoe also with fabricated frame mount adapter on my IHC 484. Frequently remove front bucket in tight spaces, there are no issues with front end lifting in the air. I dont push snow with it anymore using 6 ft bucket because it is a 2WD tractor. Even W/O the bucket, the FEL is adequate balance. If hoe attactment is within 3 point rating, tractor should be in balance with FEL attached. Also had a dedicated TLB with FEL, IHC 2400B 2WD and it was a. beast in snow but a very heavy machine. So feel free to relax. The Long hoe was private label, made by koyker in the Dakotas. Long tractors were manufactured in eastern Europe.
Ray 66v
Not sure where this is going. Point made was that the weight of the backhoe implement must be within capacity of three point linkage even with a subframe mount. Also since the backhoe would be used primarily for ballast, doing winter snow removal, an offsetting
Tool or implement would be front mounted. A FEL with bucket or blade or blade alone with subframe mount to raise and lower. The backhoe should then be in balance with the tractor as a unit. If the point is to castigate tractor owners in that catagory, it appears you battle will be entirely uphill.
Ray66v,
Even with the snow blower on the drive surface, and if there is ability to suspend the front implement in a float position, the front end would still lift the blower in the case you describe. At that point the hoe is counter balanced unless the hoe is not mateced to the tractor. If you read what I stated, the hoe attachment must be rated for the weight capacity of the 3point hithch, without regard for the use of a subframe mount. Is the blower attached to the FEL or mounted on a subframe, driven from the mid PTO. ?
Off topic... is that a tri-pacer?
