pmsmechanic
Elite Member
- Joined
- Dec 6, 2013
- Messages
- 4,225
- Location
- Southern Alberta, Canada
- Tractor
- 4410 and F-935 John Deere, MF 245
As a rule black smoke is fuel, blue smoke is oil and white smoke is water or antifreeze.
Thanks guys for all your help I am trying to find someone local to look at it. I don't want to take it to the dealer for repairs.
My Ford 1920 (1989) with 1000 hours does the light blue smoke thing also.
I see wet stains at the very top of the muffler, where the little stack is attached.
I am thinking that is excess diesel fuel (inside of pipe gets black very quickly too)..
Am planning to have the injectors rebuilt, to see if that will cure both the wet fuel look, and the light blue smoke.
Do you ever work this tractor? I'm talking about working it hard enough that that it lugs down in rpm once in a while. To me it sounds like that's what your tractor needs.
I'll tell you what I do. All winter my tractor just does easy work like blowing and pushing snow. Or moving vehicles etc in and out of my shop. Come spring I rototill gardens. Pto speed is 2600 engine rpm. Full throttle empty is about 2800 rpm which is where I rototill at. Most of the time i'm down to 2500-2600 rpm while rototilling with occasionally going a lot lower than that. What I want is for the engine to get warm enough to blow all of the unburnt fuel from winter out. Making it work does that.
The engine had about 1000 hours, the reason for rebuild was a little thing called starting fluid.The engine was bored with new pistols and rings plus the head redone.
