LightningCamaroGuy
Gold Member
- Joined
- Dec 31, 2016
- Messages
- 284
- Tractor
I want to know what y'all options are when comparing these two tractors. I'll give you my opinions of what I like better about both tractors. I've been bouncing back and forth on which to buy for a while now and I like them both.
I've looked at the current tractor market for about a year now and am getting close to the point of getting a new tractor. I've decided between either a newer JD 5075E or a MF 2607H. This will be used for up keeping my property I'm about to build a house on, (32 acres) hay farming 60+ acres, woods work, etc.
I will likely buy one without a loader and I may add one later but not really sure yet. I've always had a real love/hate relationship with FEL's. They're extremely useful and you can use them a lot but when I don't need one I hate having it on the tractor. On top of it they add a lot of cost to the machine. Growing up we never had tractors with a FEL (even though my grandpa had an old Ford Balmar) and we got by, but my dad has gotten to the point where all his new tractors have FEL's and he's adamant that I'll regret not getting one on a new tractor.
Anyway if cost wasn't an issue then I would say the JD all day.
Pro's for the 5075E I'm optioning out in order from most important to least as I can see them:
-12x12 PowrReverser transmission (huge plus and seeing as I'm use to older tractors that would spoil me like crazy)
-The spec's on the JD HL240 FEL are twice as good as the spec's on the MF 911X FEL.
-5075E is more popular and will likely be easier to find parts for and repair when the tractor is out of warranty.
-Wet clutch instead of dry clutch like the 2607H has.
-JD has a 540E PTO.
- 3PH is rated to lift about an extra 400 lbs over the MF.
-The tilt steering, electric PTO, and cup holder aren't necessary, but they are nice creator comforts that the Massey is missing.
-The hydraulics look to flow a little more on the Deere.
Pro's for the 2607H from the most to least important as I'm seeing them:
-2607H looks to cost around $5,500 less even though you don't have to get the Deere with the PowrReverser transmission but it adds a lot of features that I listed as bonuses for the Deere and I prefer the MF 8x8 shuttle to JD's 9x3 shuttle. This is also considering I'm optioning the Deere with the loader ready package which is around $1100.
-MF has better financing options than JD.
-No DPF on the 2600H series. I'm pretty sure it has no regen cycle.(huge plus for the MF IMO)
-I find the 2600H series more comfortable than the pre-2018 5E. The hump over the tranny is lower, the foot throttle better positioned, more room to spread out as there is no remote for the FEL on the floor. The Deere's tilt steering is nice though. The 2600H's ergonomics as quite improved on over the older 2600 series ergonomics, but so are the new 2018 3 cylinder JD 5E series over the older models.
-The 2600H series has great weight and is about an extra 150 lbs heavier than the 5E series.
-The 2600H 3PH is both a Catagory I and II setup where you can option one or the other on the 5E.
-MF comes standard with dual rear remotes which is about an $1,100 option on the Deere.
-The MF comes standard with telescoping draft links which is about a $750 dollar option for the JD.
-IMO these are the two most attractive tractors in their class but I do find the 2600H series better looking. It's a modern looking old school style of Ag/utility tractor IMO. I dig it's style and yes looks do mean something when spending this type of coin IMO.
-The MFWD and steering components for the MF seem better protected than the Deere's even though the Deere's don't seem poorly protected.
-Prefer the MF gas tank location even though I think the Deere's tank in noticeably larger.
I've driven a 5055E 4WD and a 2606H 2WD. I probably like the Deere a little better but I don't know if I like it more enough to justify the extra cost or poor financing options. Either machine is plenty enough for what I should need IMO. What do y'all think?
BTW I found out that the 2018 5E series are just starting to trickle in and have some nice ergonomic upgrades for over the 15-17 models. The DPF is smaller and so the hood is now 3.5" lower and 4" narrower even though it's hard to tell without them side by side IMO. I do think the front of the hood doesn't poke out as much. The hand throttle is now mounted on the right fender and 12" closer to the operator. The foot throttle is way better positioned. It's more out from under the left brake petal to the right of the platform. The loader leaver is supposed to be redesigned which now allows for more right side leg room and that justified the foot throttle relocation. I think there is like 20% more room for the operator on the 2018's platform. The seat is noticeably bigger and better padded. The battery is now located on the right side of the operator platform where the old right side step was. There is no longer a step on the right side of the tractor. They had some 2018 2WD 5045E's without loader or the floor mounted hand control, but they said they likely wouldn't be getting any 2018 4WD 5075E's until May or June. Still I was impressed with the ergonomic improvements. They were very noticeable and the 2018's are definitely more spacious and comfortable than the 15-17 5E's. Losing the right side step kind of sucks but with the hand remote it was hard to use anyway. There may be other improvements but these are the ones I was told about or remember.
Hope this didn't turn into too long of a read.
Thanks,
Jesse
-JD has a 540E PTO.
Thanks,
Jesse
