What Finish on this Stool?
   / What Finish on this Stool? #1
HillStreet
Maine
Kubota B2650HST. Kubota Z125S
I have a stool in the shower that is made of wood on an aluminum frame. The wood is very dense, stained and varnished. The varnish is coming off, a result of being in water every day. I took it out and it is dry, now what kind of finish would I put on it to not happen anymore.
The stool is good quality, made for this purpose.
   / What Finish on this Stool? #2
I would think some sort of marine application.
   / What Finish on this Stool? #3
   / What Finish on this Stool? #4
I second the epoxy & varnish route. I use that one the wooden vanity tops that I make and haven’t had an issue with it failing.
If there are any spots that appear to have a little rot or deterioration in the wood, I’d use a deep penetrating epoxy first.
   / What Finish on this Stool? #5
Sand it to bare wood and use teak oil. I don't think any varnish will last...
   / What Finish on this Stool? #6
If you can find Pure Tung Oil, that will last forever and be water proof. It does take several coats for effective water proofing but is it very thin and dries fairly fast.
   / What Finish on this Stool? #7
Linseed oil works well and is easy to re-apply when necessary.
   / What Finish on this Stool? #8
A couple thick coats of spar urethane all the way around will do the trick. Make sure you sand between coats.
   / What Finish on this Stool? #9
There is no finish that's going to stay on in the shower. Use an oil finish as suggested and be prepared to re do it occasionally it will be much easier than any kind of hard finish coat.
   / What Finish on this Stool? #10
The wood could be encapsulated but it would need to be thoroughly (like kiln) dried prior...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2001 VOLVO A35D WATER TRUCK (A51242)
2001 VOLVO A35D...
PORTA CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTA CABLE 150...
2013 UTILITY VS2DX 53FT DRY VAN TRAILER (A51222)
2013 UTILITY VS2DX...
2013 Dodge Journey SXT (A50324)
2013 Dodge Journey...
2008 MACK GRANITE HOT OIL (A50854)
2008 MACK GRANITE...
