Homeowner chainsaw rec.
   / Homeowner chainsaw rec. #81
Moss,
To stray from topic a bit, but how is heating with locust? I’ve always heard it can burn too hot, be hard to control, warp stoves, etc...?
   / Homeowner chainsaw rec. #82
You have to send your money somewhere. I spent a good percentage of it on tools and equipment. I’ll skip the Miami vacation. Purely from a logistical standpoint my pro saw cost about what the wood I’ll burn in a year is worth and makes the job a lot easier and faster. I’ll save that much again off the gas bill.
   / Homeowner chainsaw rec. #83
There are other brands that are just as good or better than Stihl, but their in your face advertising is what makes them move.
Stihl has the most market penetration due to sales and support.
It sounds like Dolmar needs to build a better sales network if they are ever going to be a big brand. Assuming they want to be.
I do not doubt they are good saws, I just do not think they are better saws than Echo, Husky and Stihl.
   / Homeowner chainsaw rec. #84
I also have an old Craftman 18" saw that I got for free from a neighbor. It uses the same bars and chains as the Poulan.
It most likely IS a Poulan. My old Craftsman 18" is.
   / Homeowner chainsaw rec. #85
"Dolkita" (sic) is far and away better than any of the more commercially recognized names in saws out there. Yeah, it's a pretty bold statement... In my experience: far greater power-to-weight ratio, unsurpassed antivibe, better fuel economy and lower overall service cost plus better dealer support than any of the others - where you can find a dealer that is.
Market saturation through the box stores or even privately owned dealers on every streetcorner just doesn't equal the quality that everyone is convinced exists.
My opinion, and like Grandma used to say...
   / Homeowner chainsaw rec. #86
Isn’t dolkita, dolmar, and makita the same thing?
   / Homeowner chainsaw rec. #87
Makita ChainSaws
MAKITA AND DOLMAR ARE MERGING INTO A SINGLE BRAND: MAKITA POWER EQUIPMENT. Under the Makita brand, this integration gives users a full range of professional chain saws for forestry, farm, and occasional use.
Bruce
   / Homeowner chainsaw rec. #88
I have a 50cc Stihl and a 55 CC Echo, both from 1990 and 1998. Both run pretty good but they weren't fast enough because of their .325 chains. I can remember taking almost a tank of gas going through a 36" oak with either of these saws. It was painful.
I just bought a 60 CC Echo higher end saw with 3/8" chain last year. The Echo will chew threw a 18" log approx. in 20 seconds where the other ones will take a minute plus for the same cut. It may not sound like much time and it may not be, but it is 45 seconds less wrestling with a pokey saw. It just makes life a lot easier.
   / Homeowner chainsaw rec. #89
With that extra 45 seconds you’ll cut 3 times as much wood in a day before you get tired. If people would quit bashing nice things before they tried them things would be a lot less confusing here. You’ll never hear the pro saw owner, GrandL owner, or backhoe owner bashing them.
   / Homeowner chainsaw rec. #90
A 5 or 10cc difference in displacement plus the difference between a 0.325 and 0.375 (0.02 difference) saw chain is not going to make a 60 second to 20 second difference in cutting speed on an 18” peice if wood if both the saw and chain are maintained. Something else is wrong with your 50 and 55cc saws.
   / Homeowner chainsaw rec. #91
The difference in mine is 21 cc and running the same chain. ( wrong chain on little saw ) The difference in cutting time is substantial. The power difference is 50 percent and the cutting time is easily double. Probably 3 times faster.
   / Homeowner chainsaw rec. #92
Moss,
To stray from topic a bit, but how is heating with locust? I致e always heard it can burn too hot, be hard to control, warp stoves, etc...?
I love it! It's heavy wood. And it takes a couple years to dry out, although it will burn when wet pretty well, actually, which is surprising. But that will build up soot pretty fast in the pipe, and reduces the heat output considerably because you're boiling water. So, I don't do it. Did it a few times in a pinch when we first got the stove, but after seeing the spark screen on top of the chimney pipe soot up in just a month or so, I started realizing what was happening and stopped that.
I have a Napoleon wood stove. It has a single air control. Once I get a fire going, no matter what the wood, if I shut the air down all the way, it'll damp off the fire nicely no matter how hot it got before closing the air control. I will say, though, that the locust CAN burn way hotter than anything I've ever tried. I just don't let it burn that hot. A couple times I did forget that I had the fire started and gone downstairs to see the thermometer pegged things just a blazing away. But the stove never got red hot. All I do in that situation is open the door wide open and toss in another log. Opening the door stops the jet-like air flow from the stove vents and the new log takes a lot of energy out of the fire. Just a couple minutes, then I close the door and shut off the air and the fire dies right down to normal.
I burn locust almost exclusively, but I will do a downed tree for friends, family, etc... so I have some maple and cherry and oak to compare it to. I get about 4-5 hours of burn time from those woods before its a bed of coals. I get an honest 9-10 hours with the locust with the same air control setting. I load it up when I wake up in the morning, get it going real good and shut off the air control all the way about 10 minutes before I leave for work. Check it again on the way out the door to make sure the fire came down. When I get home, 9 hours later, I'll still have a 400 degree stove, and the room is still 80 degrees and my blower is still moving hot air upstairs. If I do that with cherry, oak or maple, the stove is 200 degrees when I get home, and the room is in the low 70s, and the blower has shut down. Throw in about half a load of wood when I get home and that's good until bed time. Load it to the top when the 11:00 news comes on, and shut down the air at 11:20 and it's good to go until morning again.
All-in-all, locust is a great firewood. For quick fires, or just cool evenings I'll use the oak, cherry, maple, etc... but if I want a long burning fire, its gonna be locust. :thumbsup:
   / Homeowner chainsaw rec. #93
Very well could be. It's probably 20-30 years old. Built differently than the Poulan Pro. Same displacement. The clutch is located outside of the drive sprocket on the Craftsman and inside of the drive sprocket on the Poulan. Mufflers are in different places, to. But I realize designs change over the years.
   / Homeowner chainsaw rec. #94
You have to send your money somewhere. I spent a good percentage of it on tools and equipment. I値l skip the Miami vacation. Purely from a logistical standpoint my pro saw cost about what the wood I値l burn in a year is worth and makes the job a lot easier and faster. I値l save that much again off the gas bill.
I don't get the correlation between expensive chainsaws VS cheap chainsaws VS denying yourself a vacation???
:confused3:
   / Homeowner chainsaw rec. #95
:confused3:
I didn’t not go to Miami and instead buy a chainsaw. The point was some people want to drive nice cars and go to concerts every weekend. I’ll drive junk vehicles and the beach and concerts don’t do anything for me. So that leaves funds for equipment and tools that aren’t essential.
   / Homeowner chainsaw rec. #96
The beach does nothing for you? Man, you don't know what you're missing....
537583d1517192563-homeowner-chainsaw-rec-7bae768d-71ba-4354-a1b3-51bad095c88e
   / Homeowner chainsaw rec. #97
   / Homeowner chainsaw rec. #98
We've been there many times, too. Smokies, skyline, blue ridge, appalachians, TN, KY, NC, SC, WV, VA, MD, GA, FL, MI, OH, PA, IL, IA, MN, SD, ND, WY, MT, KA, NE, AZ, NV, CA, HI, MA, NJ, MO,.... point being, there's so many great places to see in the U.S., you should get out there and see them.
   / Homeowner chainsaw rec. #99
I’ve been to the beach, up north and out west. I never said I was anti travel. I am anti expensive things you can’t afford and ball games or concerts every weekend. The beach was definitely one place I could live the rest of my life and never go back. Yellowstone in the winter is one place I would recommend. IMG_8726.JPGIMG_8841.JPG
   / Homeowner chainsaw rec. #100
If you put the factory recommended chain on the 50 cc it would narrow the difference. Is there a substantial difference? Yes. But the difference between the speed of a 50 and a 70cc class saw on a little 18 log is not a factor of 2 or 3 all else being equal. It just is not.
16ft T/A Utility Trailer (A59231)
16ft T/A Utility...
MINI KID DIRT BIKE (A56859)
MINI KID DIRT BIKE...
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
MODEL 14C SCRAPER (A58214)
MODEL 14C SCRAPER...
