Determine remaining welding gas in cylinder
   / Determine remaining welding gas in cylinder #1
Tractorguy24
BC, Canada
Is it possible to determine how much c25 gas I have left in my 330 cu ft.cylinder? Is there a formula or some rule of thumb? It is at 200psi right now.
Thanks!
   / Determine remaining welding gas in cylinder #2
Not that I'm aware of. Being it's dispensed by the CFH and everyone runs a little different flow. From being in the same boat a few times I'd guess you have a half hour left. 330 cf in the tank when new can be calculated to how many trigger pull hours the tank will last if you had kept track. Who does that? Time to buy.
   / Determine remaining welding gas in cylinder #3
My current gauge set up will run them down to zero and out. Strangely accurate. Not all do though. It's time to be thinking about project needs and getting gas though. I wish I could have a 330.
   / Determine remaining welding gas in cylinder #4
"Ideally" the formula is PV=nRT.
...but can you weigh it, though you'd need to know the full and empty weight?
   / Determine remaining welding gas in cylinder #5
Thanks!
Without any fancy formulas, if you started out at 3000 psi at room temperature, and it now reads 200 psi at room temperature, you now have 1/15th the gas. 1/15th of 330 is 22 cubic feet.
   / Determine remaining welding gas in cylinder #6
I don’t think it’s that easy. I think doubling the pressure wouldn’t double the gas volume.
   / Determine remaining welding gas in cylinder #7
Do you think that doubling the gas volume would double the pressure? In a fixed-size cylinder, of course.
   / Determine remaining welding gas in cylinder #8
All that useless math that people say they are never going to use again.... SMH
   / Determine remaining welding gas in cylinder #9
I don’t know. But I really doubt it’s that straight forward.
   / Determine remaining welding gas in cylinder #10
It's about that easy. You will get flow right down to the last psi. I was pretty close guessing 1/2 hr of trigger pull left. I was using 25cfh as a guideline.
UNUSED FUTURE 36C STAD ON SKID STEER (A57192)
UNUSED FUTURE 36C...
2021 Kubota RTV X900 4x4 Utility Cart (A55787)
2021 Kubota RTV...
2014 Jeep Compass 4x4 SUV (A55853)
2014 Jeep Compass...
2016 JLG 20MVL 19ft Aerial Platform Lift (A55851)
2016 JLG 20MVL...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2013 Chevrolet Silverado 1500 (A55973)
2013 Chevrolet...
