Ford 1510 injection pump lubrication
   / Ford 1510 injection pump lubrication #1
nate1616
Milton, fl
1510 ford
On a model 1510 ford tractor with a shibaura engine, how is oil circulated to the cam box to lubricate the injection pump, the lifters and rollers and the cam gear? Thank you for any help.
   / Ford 1510 injection pump lubrication #2
Splash oil from the front cover.
   / Ford 1510 injection pump lubrication #4
Do you have a photo? On a 1700 the injector pump holds about 2 oz of oil and has a oil level and drain plug, small screw. Not to be confused with oil in the timing gear area.
This is the best pic I have of the side of the cam box at the moment. This was before tearing it apart. I tried everything you can think of, and am aware of the drain and fill plug on the side of some cam boxes. The only thing I came up with is oil is carried up by the timing gear and splashed into the cam box. U have the timing cover back on but any other thoughts would be appreciated. Thanks
   / Ford 1510 injection pump lubrication #6
YOU have a PFR pump on your engine.. its driven by an "external camshaft" that's lubricated by the ENGINE'S oiling system..
The other person has a Diesel Kiki INLINE pump & it has an "internal camshaft" that's lubricated by a self contained oiling system.
HE adds oil to his pump..
New JMR Skidloader Boom (A50774)
New JMR Skidloader...
2012 MACK CHU613 DAY CAB FLAT TOP ROAD TRACTOR (A51243)
2012 MACK CHU613...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2012 Ford F-250...
2017 Volkswagen Jetta (A50324)
2017 Volkswagen...
1993 Harsh Feed Mixer (A51039)
1993 Harsh Feed...
2014 UTILITY 53FT DRY VAN TRAILER (A51222)
2014 UTILITY 53FT...
