How do you fill your 10 series with a field cab?
   / How do you fill your 10 series with a field cab? #1
KenGod
PA
CK2610HST
Love my new 3510 with field cab but I find it a huge pain to fill the new relocated fuel tank.
I use 5 gallon cans, I cannot empty the can fully due to the rear glass preventing me from tipping the can all the way up.
I looked for a fuel tank extension but came up empty :)
Has anyone come up with a bush fix other than getting a large tank with a pump system?
   / How do you fill your 10 series with a field cab? #3
Even with the EZ-Pour, the fuel has to enter the spout in order for it to drain out. I think the OP's issue is that he can't tilt the fuel can up high enough to drain it all...not how fast it drains. Siphon might be another option.
   / How do you fill your 10 series with a field cab? #4
Have a similar problem with my CK3510SE. A “standard” 5 gallon diesel can won’t let you easily get the last gallon or so into the tank because of the location of the filler neck on the tank to the cab. I am comparing a couple of 30-50 gallon fuel caddies to use instead of cans. I burn a relatively small amount of diesel in the winter so may hold off on a purchase until spring. I have tried several different types of diesel cans and unless I am messing around with holding a funnel in the tank and pouring the Fuel into that I have the same issue.
   / How do you fill your 10 series with a field cab? #5
With the added “8” extension, I think it would work fine. If you can’t fuel with 16” spout, you’ve really got a problem?
   / How do you fill your 10 series with a field cab? #7
I agree. A longer spout should do the trick, but I still consider it a design flaw...after all, standard fuel cans don't come with long spouts. How did Kioti engineers thing owners were going to refuel their tractors?
   / How do you fill your 10 series with a field cab? #8
Is this what we’re talking about?
   / How do you fill your 10 series with a field cab? #9
I have been wanting to comment, but I am not familiar with 3510's, & I'm not really even sure what a "field cab" is. Be that as it may, Rick's picture (above) gives me the confidence to ask why can't you just open the rear window, & have all the room in the world? Seems like you would even have a 'ledge' to support the gas can while you poured??
Please keep in mind that I am not familiar with 3510's (and/or field cabs)
Looks like Im going to need to get new cans and try that High flow extension, I have 3 of these, you can see how short the spout is.
I could try and open the window. I read that once I put the backhoe on the seat will be in the way
JD Z225 ZTR Mower **Does Not Run** (A50121)
JD Z225 ZTR Mower...
2011 Chevrolet Malibu Sedan (A50324)
2011 Chevrolet...
3pt Cult. & Pipes (A50121)
3pt Cult. & Pipes...
7' Bi-Parting Gates (A50121)
7' Bi-Parting...
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
R&G Trailblazer 1000Gal 28% Applicator (A52349)
R&G Trailblazer...
