Toolbox sugjestions
   / Toolbox sugjestions #1
Spentit
Peyton Place NH
Mahindra 2565 with hoe, Case 530 back hoe, Hyundai180 LC-3 excavator. Love my Hoe's!
Am soon to take delivery of a low hour Mahindra 2565 cab shuttle. It was priced right so I thought I would give it a try. In the past I worked a different model Mahindra and it had a toolbox under the floor mat. It wasn't to big or to small. And it was right at the door with a steel lid. It was great. I have yet to see anything about this 2565 having any toolbox. Has anyone come up with any good ideas on location, what you might have done. I don't want to fill the cup holders with extra pins and tools. Maybe it has one hidden somewhere, I can't find it. Every tractor needs a tool box.
   / Toolbox sugjestions #2
i put an ammo box in the back behind the seat and attached with the screws from the triangular-like reflector caution sign in the back - works great - drilled a couple of holes for basic drainage. works for what i need generally. got the paint to match tractor at tsc.
there is a thread here in another area of the forum. cannot find the link. maybe i never saved it. sorry.
   / Toolbox sugjestions #3
oh i also have an extra that i could attach to the side of the rollover bar too. installed and decided did not like it there - but that does work.
Good idea behind the seat. Then I could reach it through the back window. Thanks.
   / Toolbox sugjestions #5
When I had my first tractor - Ford 1700 - I put a military 45 auto ammo can on the fender. It was OK - wx tight and just the right size. Only down side - at certain speeds the fender and ammo can took up a vibration. Not a lot, but I wrapped loose hand tools inside the can in shop towels to cut rattling.
   / Toolbox sugjestions #6
tractor paint
Tractor Supply MAJIC brand Tractor, Truck and Implement Spray, color IH RED the code on the cap is 8-22972
   / Toolbox sugjestions #7
What ever you do DO NOT modify the roll over bar. The bar is built to specs for your tractor. If you drill holes in it or such you will weaken it. It is ok to bolt things to it, like a tool box. Tractor Supply had U-bolts that looked like they were custom made for my roll over bar.
I used an old chest freezer basket and some Dexion to make a basket that I could just toss stuff into. I mounted it to the roll over bar with the Tractor Supply U-bolts.
   / Toolbox sugjestions #8
no inserted it into a pre-existing bolt. or used a free hole - do not remember. i am not a numbnuts re: messing with the structural integrity of stuff. my Ph.D. is worth something plus all my work experience.
   / Toolbox sugjestions #9
Would you mind posting a PIC please?
   / Toolbox sugjestions #10
sorry tried 3x to upload and the upload page goes off the screen and then froze plus site was slow too. had to reboot my laptop - linux too which is weird - sorry man.
   / Toolbox sugjestions #12
Ammo box lower on the side
All great ideas. Mine has the cab with lots of plastic trim. Havn't taken delivery yet so can't dig in quite yet. Kinda like a blind peeping tom, They can only imagine what it looks like.
   / Toolbox sugjestions #15
I was ALL excited when I saw your pics, etc. and went out to look at the tractor today when plowing the 1300' driveway and it dawned on me that you all have ROPS (open station) and I have a CAB....does me no good at all. :(
My thoughts too.
   / Toolbox sugjestions #18
I just bought a small Craftsman tool box and fab'd a mount to attach it to the ROPS. It has small compartments in the lid that I used for extra pins etc., has a lift out tool tray, and room underneath it for some small standard tools. It is light duty plastic, but should be OK as an emergency tool kit out in the field. Time will tell, but heck, it was only $6 on sale so if it doesn't hold up I'll get something else. :)
Craftsman 13 Inch Tool Box with Tray - Black/Red
   / Toolbox sugjestions #19
I have a cabbed tractor with no convenient place to install a tool box. Finally decided to place one behind the seat on the 3 inch wide base of the cab mount.
Since it was so narrow I looked for a longer size tool box and found one that is 20" long, 5" wide and 6.75" high. Bolted a piece of 2x6 and and 1/2" boards to raise the mounting surface so I could slide the tool box back toward the lower window of the cab so as to allow space between the seat back and still allow the lid to open up and stay open. I can access the tool box by tilting the seat forward or through the open back window. Now I have a place to carry tools and extra pins, bolts etc.
   / Toolbox sugjestions #20
I used 4” PVC attached to the ROPS - with screw on tops and it works for me ...IMG_3179.JPG
SWICT 84" SKID STEER BUCKET (A60430)
SWICT 84" SKID...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
2024 BOBCAT MT100 STAND ON SKID STEER (A60429)
2024 BOBCAT MT100...
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
2006 CATERPILLAR 420E BACKHOE (A59823)
2006 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
