8n wont stare
   / 8n wont stare #1
Bandit2026
Ferrum, VA
Ford 8N, Kioti CK35
Starting a slow restore of my 8n not for show just a good cleanup. Was getting where it would miss a lick once in a while so I got a tractor supply tune up kit. Installed and fired right up all was good. After about 2 mos of very cold storage she would not fire. Getting fire to front mount coil top and bottom , checked and cleaned points still no fire to the plugs. Any Ideas??
   / 8n wont stare #2
Could be a bad coil that has cracked internally causing the secondary winding (spark side) to open due to the cold. Seems you have replaced everything else, good luck.
   / 8n wont stare
thanks That sounds like a great possibility as it got down to about 9 degrees a couple of times.
   / 8n wont stare #4
Please pull one of the spark plugs and verify you are getting blue/white sparkies or invest in spark tester shown below that will also provide spark intensity.
   / 8n wont stare
I've tested it with plug in and plug out grounded to block and nothing.
   / 8n wont stare #7
Do you have a link showing where that tester can be purchased ? All I can find is the pen type that show if there is a spark, or not. I would prefer one that actually shows how strong the spark is like you posted, but cann,t find it.
   / 8n wont stare #8
Auto craft tester at advance auto parts for 8.99, came up when i googled it.
   / 8n wont stare #10
Have you changed the condenser, they used to always be included in the kits, now they aren't. A bad condenser will drive you up a wall trouble shooting ignitions.
2001 JOHN DEERE 310G BACKHOE (A52705)
2001 JOHN DEERE...
2 windsor 351 inboard motors w/transmissions shafts rutters and props (A53424)
2 windsor 351...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
ROLL OFF BOX (A53843)
DESK (A53843)
DESK (A53843)
2011 INTERNATIONAL PROSTAR SLEEPER (A53843)
2011 INTERNATIONAL...
