hydraulics ( the front end loader on a Kubota
   / hydraulics ( the front end loader on a Kubota #1
Don L W
Orono
B7200D 4wd
Ive blown a front hydraulic line to one front end loader, on a Kubota B7200 series 4x4 standard . Ive now replaced the line that blew and now after replacing some of the fluid. the hydraulic's and don't work anymore . I have since looked for anymore leaks to no avail and also contiued todrop the transmission/hydraulic fluid to check the filter, which to my disgusted eyes , the filter is clean !
dose anybody know anything further that i can check before digging further in to the trasmission/hydraulics tocheck or replace a pump ???? Auh help going crazy lots of snow on the drivway and more on the way here in Canada, im not used to manual labour nor a heart attack lol ???????????Somebody it would be a God cent , if this is a quick fix
   / hydraulics ( the front end loader on a Kubota #2
Go back to the beginning. When you replaced the line did you unfasten any other lines so there might be a mistake in how they are now fastened??
Do you mean the loader doesn't work now? The tractor is okay?
   / hydraulics ( the front end loader on a Kubota #3
Did you bleed the air out of the system?
where would you start to bleed the air and persicley the location and any special tools i need to have . i am a pritty good average mentality toward mechanical ****
   / hydraulics ( the front end loader on a Kubota #5
The system will bleed it self . Did you take off any quick disconnects when you changed the hose ?
   / hydraulics ( the front end loader on a Kubota #6
There should be no need to bleed anything...cycling the circuit that had the hose replaced should expel the air out through the tank...
Try resetting any quick disconnect that on that circuit...sometimes QD's will hold a bubble of air...
   / hydraulics ( the front end loader on a Kubota #7
Well? Can you get it to move? By "4x4 standard" do you mean standard transmission?
Have you done those things? Also what's the environment? Did you work on everything outside or in a nice warm garage?
The hydraulics will work slower, and bubbles flow slower, when COLD.
2012 Kia Sorento SUV (A51694)
2012 Kia Sorento...
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
ALLISON TRANSMISSION (A53843)
ALLISON...
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
