Winter Driving Tips
   / Winter Driving Tips #51
Another thing I can think of that has saved a stop sign post or two, is to look for escape routes BEFORE you need them, should you have to think fast. For example, you're approaching a stop-sign on a downhill, and here comes a car from your left, trying to make a right turn towards you, but missing the turn and sliding across your lane. You have no where to go, and you have to slam on the brakes, and your lane is icy. So, look for the areas between and next to the icy tire tracks in your lane and see if there's grippable snow in there. Look at the area right next to the curb. It may not be slicked up by stopping cars. Look at the area to the right of the stop sign. Is it just someone's lawn and bushes? Go for it! Several times I've had to dive to the right of a stop sign to avoid being hit. I've damaged a rim or two over the years, too, but it beats damaging the left front corner of your vehicle, or being hit in the driver's side door.
   / Winter Driving Tips #52
A deductible is $1000 ( at least for me). The ditch doesn’t sue or raise insurance rates.
   / Winter Driving Tips #53
I can't speak for all ABS systems but the ones I have used in my newer cars are fantastic! Have saved me from numerous slides through stop signs. The thing I like the most about ABS is that it alerts you very quickly that you are in a slide situation; to which my reaction is always to eas up on the break a little but not so much that I don't still get stopped.
I know for a fact my ABS acts more quickly than I do; can't speak for yall.
   / Winter Driving Tips #54
Throw in ABS with stability control, and you have something when it comes to emergency maneuvering...
I'm pretty convinced those two things saved my kid's life one snowy night out on the highway when a semi passed her and she lost control. She said she screamed, took her hands off the wheel to cover her face, and the car sraightened itself out. She didn't know how. I do. ;)
   / Winter Driving Tips #55
Good video Moss.
Another that will make you a believer
How Effective is Stability Control - YouTube
Last week 71 North of Columbus was an absolute mess 3 - 4 inches of slick snow. I waited until I had no cars around me and punched the gas just to see what would happen. My car did not get very squirly at all and it was slick.
   / Winter Driving Tips #56
Good video Moss.
We had a 2000 Impala with traction control. With good tires, it might as well have been a snowmobile. I loved driving that car in the snow. Stomp on the gas and it would take right off, with just a bit of braking if it sensed wheel spin. Our 2013 Impala's traction control is, to me, too aggressive. If I stomp on the gas, it won't let the car go forward much, at all, as it applies the brakes to keep the wheels from spinning. But the 2013 has the stability control, while the 2000 did not. I have not yet (or at least not known) use the stability control, but I'm sure my kid did.
Now my 1993 Suburban K1500 is another beast all together. It's 4wd with a locking differential in the rear. I have absolutely no issues getting moving forward in snow. None. It handles really well if you use engine braking, downshifting, and gas pedal to get around curves and such. Stopping..... not so good. The ABS system leaves much to be desired. I think it fights with the drive train. I can go out and try and stop, and hear and feel the ABS going off, and keep on sliding. But I can go around the block, and approach the same stop, but throw it into neutral, and it'll stop just fine. It almost seems as if the front wheels start skidding, the rear wheels keep driving it along, regardless of if its in 2 or 4wd. I'm tempted to pull the ABS fuse(s) and see if I can disable the ABS to test it out.
   / Winter Driving Tips #57
I'd take that bet.
I think ABS are great on dry pavement, allowing people to steer and brake.
Yes, I know how they work.
I've experienced it pulsating the brakes. And I've experienced that the stopping power of the ABS releasing the brakes was lesser than if my studs where just locked and digging in.
You can feel it plain as day when on ice you go from braking, deceleration, to when the pedal starts pulsating and there's no more feeling of deceleration, and you're not stopping.
Wikipedia sources (notated) says: "ABS generally offers improved vehicle control and decreases stopping distances on dry and slippery surfaces; however, on loose gravel or snow-covered surfaces, ABS can significantly increase braking distance, although still improving vehicle steering control."
Anti-lock braking system - Wikipedia
I agree. The key is to avoid getting to that point at all. You have made a lot of mistakes by the time you slam the brakes to the point that ABS is kicking in. Following too closely, going too fast, not downshifting long before you needed to engage the brakes to come to a full stop. In the snow, ABS is a safeguard for people who don’t know how to drive. It might slow the vehicle down a little bit and reduce injuries by the time the out of control vehicle slams into something.
   / Winter Driving Tips #58
Ha right. You don't have to slam the brakes for the ABS to kick in on a newer car. I drive as fast as I can get away with and if that means I can't drive; I guess I can't. I prefer not to spend any more time on the road than I have to. I spend 10 hours a week minimum in my car commuting.
So I love my ABS and ESC. If it kicking in means I can't drive I don't really care.
So your the guy clogging the fast lane!
   / Winter Driving Tips #59
Remember we are talking modern ABS.....not 1990's tech.
And that quote from wiki.....not the whole story.
The though behind stopping faster on snow and loose gravel WITHOUT ABS is simply because the loose stone or snow will pile up in front of the tires when a tire skids (further aiding in stopping) where ABS doesnt allow that to happen. But I certainly wouldnt say that ABS "significantly" increases the stopping distance. A little increase...in SOME conditions....maybe. But at a loss of directional control.
I disagree.
Slippery snowy roads and someone pulls out in front of you causing you to brake hard enough for ABS
Or a dog, deer, kid, whatever darts out in front of you?
Or someone coming at you and cannot stay in their lane?
Or you round a blind curve and and realize your lane is blocked because of an accident?
None of these are "people who dont know how to drive" Emergency braking is a part of driving. Having to do it doesnt me one doesnt know how to drive. And in a panic situation....you bet your @$$ I want ABS,
So all you you big tough guys.....go ahead....keep pounding your chest because you think you are better than ABS and ABS is for the weenies. I'll stay in reality. I have nothing to prove about how good of a driver I am that I dont need ABS.
   / Winter Driving Tips #60
I always heard that the difference was when you get a 4x4 stuck...you're really stuck...!
How do you know who's 4 WD is best? It's the one that gets stuck farthest from home.
All the ABS talk brings up another point. Your main focus in a situation should be on where you want to go (an opening you can fit through, the shoulder of the road, etc..). Your reflexive tendencies will try to take you where your eyes are pointed. Staring at the vehicle you're trying not to slide into pretty much assures you will hit it.
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
UNUSED WOLVERINE LHR-51-23W 1R RIPPER (A54757)
UNUSED WOLVERINE...
Scag Mower (A50324)
Scag Mower (A50324)
UNUSED RAYTREE RMH680 HYD HAMMER (A54757)
UNUSED RAYTREE...
Adams Tender / Magnolia Trailer (A55301)
Adams Tender /...
