John Deere 300 b backhoe select hydraulic problem
   / John Deere 300 b backhoe select hydraulic problem #11
Are you thinking about a CCLS hyd system? JD 300B doesn't utilize a pilot signal to put pump in stroke merely a drop in hyd pressure which allows pump pistons to be pushed back by springs against the already rotating pump shaft allowing pump to pump oil.
Yes I thought this was a CCLS system
Does this model have the priority flow control for steering. If the hoe is working then something is blocking oil from getting to the loader valve.
   / John Deere 300 b backhoe select hydraulic problem #13
I have a 301 and the hydraulic return for everything goes through a hose to the rear into the sump. I had a valve fail internally and it bypassed to the return. Nothing worked unless something down the line caused enough back pressure.
May I ask which return line you're referring to pulling?
Update. The backhoe is working but has slowed down. I changed the pump filter. It was torn and full of dirt. If I lift the loader with another loader it will stay only a foot off the ground. I believe I have air in the lines because all worked well until I had to take the fuel tank off for repairs. I am open to suggestions as to how best get the air out.
   / John Deere 300 b backhoe select hydraulic problem #16
Yes there's a priority valve but to my knowledge both backhoe & loader are supplied oil after oil leaves priority valve.
   / John Deere 300 b backhoe select hydraulic problem #17
Suzukibruce
Previous owner must not have changed other hyd filters very regularly. Did you ever check/clean hyd oil sump screen in the bottom of trans case????
Suzukibruce
You are correct about filter and fluid changes. The first thing I did 30 tractor hours ago was change both filters and pulled the inline screen behind the 4 inch rubber hose. What a job getting that hose back on. The oil is new hygard. I知 going to try blowing compressed air in the sump to see if I get a positive reaction with the loader. Other than that I have no other filters that I know of to change
   / John Deere 300 b backhoe select hydraulic problem #19
Blowing compressed air into the reservoir helps prime the pump but I doubt that you have an air lock to the loader valve. This is a closed center system so if the back hoe is working the pump is moving oil and this oil should also be available to the loader. Can you operate a function on the back hoe and loader at the same time? If the hoe stops working this would point towards a problem in the loader valve circuit dumping oil to tank.
Yes I tried holding the loader in the up position while operating the backhoe.when the backhoe bumps the loader will move a little. I forgot to mention that before all this happened I lost the accumulator input hose. This is probably the problem. Again sorry for omitting this. I didn’t think of it at the time.
2017 Ford Fiesta Passenger Car (A51694)
2017 Ford Fiesta...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
Heavy Duty Hydraulic 84" Broom  (A52384)
Heavy Duty...
2012 Ford Escape SUV (A50324)
2012 Ford Escape...
