Ball bearing in crankcase
   / Ball bearing in crankcase #1
tmar04
YM 276
Just bought 1958 one owner TO 35.,had recent overhaul two years ago . Gas engine that runs perfect. Today I changed oil and converted to spin on filter. When I took drain plug out, a steel ball bearing size of a marble cane out right after plug!!! Where could this steel ball have come from?
   / Ball bearing in crankcase #2
Most likely came from the governor. Time to pull the front cover off and check!
   / Ball bearing in crankcase #5
Me too, I just wish they'd hold onto 'em!
Like this?
   / Ball bearing in crankcase #6
Just like that. Gotta get it to run "balls out!"
How big a job is that?? ( I知 no mechanic) what happens if I do nothing? Governor seems to work ok now .
   / Ball bearing in crankcase #8
Not bad. It may have been replaced already, but if you just recently found it in the oil pan, I'd still pull it apart and take a look. If your governor did indeed lose one of the flyballs, it's only a matter of time before it rattles itself apart.
Governor Replacement on Massey Ferguson Z engine - YouTube
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
King Kutter TG72 Rotary Tiller Tractor Attachment (A54811)
King Kutter TG72...
2018 Dodge Grand Caravan SE Van (A55853)
2018 Dodge Grand...
2008 Ford Focus SEL Sedan (A55853)
2008 Ford Focus...
