1660 Power shuttle jerk
   / 1660 Power shuttle jerk #1
hamdog
Northern
I just received delivery of a 2009 1660 with 123hrs and the power shuttle transmission. The other day when I was playing around with it, 40F and idle conditions the tractor would jerk when shifting from forward to reverse. It also does so when you slowly let out clutch.
When I test drove the tractor it was smooth as butter and non of these symptoms occurred. But the dealership supposedly serviced the tractor before delivering- hydraulic oil and filter, engine oil and filter, air filter, fuel filter etc.
What are your thoughts of the potential possibilities that could be causing this? Thank you!
   / 1660 Power shuttle jerk #2
I do not have an owners manual I will try to see if I can get one.
I was using it today and as the tractor warmed up it seemed like the jerk slowly disappeared.
   / 1660 Power shuttle jerk #4
Maybe a wire or connector is loose on one of the solenoids.
   / 1660 Power shuttle jerk #5
Trash in the reducing valve will do it every time too.
   / 1660 Power shuttle jerk #6
The type of fluid used will have a major impact on how those wet clutches behave.
As well as some changes with temperature.
Thanks guys I will look into all these. A massey realer serviced it so I assume they used approved agco products.
Also do you guys know if the DL130 loader valve can curl and lift/lower at the same time? I put about an hr of loader work on it this wknd and loader valve was slow and did allow to curl and lift/lower at once. Thanks!
   / 1660 Power shuttle jerk #8
That dual action on the valve is accomplished by slight of hand
   / 1660 Power shuttle jerk #9
As your problem has been at lower temps, I suspect inferior or improper Hydraulic Fluid.
Cheap Hydraulic Fluid is based on cheap oil and minimal performance additives.
How certain are you a M-F dealer serviced the tractor?
   / 1660 Power shuttle jerk #10
Jeffy,
You repeated the exact analysis provided by Lou, NY. Do you have any ownership experience with hydraulic shuttle transmissions ??
2004 Honda Pilot SUV (A50324)
2004 Honda Pilot...
Ran during check in. No longer running. (A51694)
Ran during check...
2019 Ford E-450 Super Duty Passenger Bus (A51692)
2019 Ford E-450...
Genie GTH1056 (A50120)
Scag Tiger Cub Zeroturn (RUNS) (A50774)
Scag Tiger Cub...
