L 2250 Hydraulic pump reseal
   / L 2250 Hydraulic pump reseal #1
albe123
Boerene,Tx
Kubota L2250
The level of crankcase oil keeps increasing. I'm assuming its a problem with a the hydraulic pump seal. I have power steering so its a dual unit. I thought I had read somewhere not to try to rebuild that unit. Is there a problem in rebuilding? The parts are available. Has anyone done it and could advise me?
Thanks, Al
   / L 2250 Hydraulic pump reseal #2
Most of the time the seal is pushed out due to a worn pump allowing pressure to leak up the shaft. You can try a new seal. But once the aluminum pump housing wears out. The price of rebuilding pretty much adds up to what a new pump would cost.
All new seals for both units were available....about 13 seals and metal seals. These parts about $60. vs about $400 for new pump if it's available. Has anyone tried to rebuild/reseal this unit?
Thanks
Al
Yes, I finally did rebuild the pump. Have about 3-4 hours on it and so far, no noticeable increase in crankcase volume.
Probably not enough time for a reasonable response!
Thanks
SCHAFFER 2430SLT LOT NUMBER 150 (A53084)
SCHAFFER 2430SLT...
1266 (A50490)
1266 (A50490)
JOHN DEERE WHP48A LOT NUMBER 107 (A53084)
JOHN DEERE WHP48A...
24in Tractor Backhoe Bucket BT4555 (A53472)
24in Tractor...
2016 KOMATSU D61PXI-23 CRAWLER DOZER (A51246)
2016 KOMATSU...
FORD 555B BACKHOE (A51406)
FORD 555B BACKHOE...
