B21 Hydraulic pump removal and seal change
   / B21 Hydraulic pump removal and seal change
Subscribing. I have been meaning to replace my suction hose (7 in the diagram) since it has deteriorated and it looks simple to replace. I don稚 have an engine oil issue but wonder if replacing the pump seal and o ring would be good to do at the same time if not too involved.
I'd just change the hose.
It is a bit of a pain, so I personally would not bother if there was no crankcase oil level increase or no leakage where the pump bolts up to the block.
When I put it back together I did used the old oring. Normally I'd change it but I did not have one on hand and it looked fine. It is not under pressure, just keeps engine oil from seeping out.
   / B21 Hydraulic pump removal and seal change #12
Good point, I do tend to grow scope of my repairs.
How many hours on your B21?
REMLINGER 2300 LOT NUMBER 59 (A53084)
REMLINGER 2300 LOT...
Toro Zero Turn (A50324)
Toro Zero Turn...
ALLIANCE 480/80R42 LOT NUMBER 134 (A53084)
ALLIANCE 480/80R42...
WB Mower (A50120)
WB Mower (A50120)
2001 Blaw-Knox PF 150 Paving Machine (A52384)
2001 Blaw-Knox PF...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
