Ag vs. Industrial tire strengths
   / Ag vs. Industrial tire strengths #11
Still in the research process for a new tractor for our mountain, farm, & client properties. Are Ag or Industrial tires tougher / stronger? When do you recommend filling them vs. not filling them? Pros/cons? Thanks!
As someone that just went from a utility tractor (NH WM55) with R1s to a compact (Kubota L6060HSTC) with R4s in the past two months I can tell you my opinion thus far.
I haven’t picked up any super heavy loads with my R4s yet other than buckets of rain soaked mud earlier this week, but I have not noticed any bulging like I would with the R1 tires I had on my last tractor. When lifting to loader max on my last tractor, which was about 1400# with my clamp on forks, the front tires would bulge bad. I filled them to max air to be able to lift heavy loads. I had the same issue in my tractor before that as it had R1s as well but was smaller with much less lift. I would say likely if you got better R1s they might not bulge as bad.
I can’t speak to stability much because I haven’t had my R4s on the hillside yet due to the mud and snow this year. But the stiffer tire feels more stable on the inclines I have had it on. It doesn’t bounce as much on uneven ground. It also rides much smoother on hard ground like the road and my driveway.
Snow traction the R4s have been much better than I would have guessed. I have yet to have an issue on my driveway clearing snow and it’s rather steep. My R1s I got to where I did not trust them on my driveway because sometimes it would lose traction on icy spots.
Mud traction on the R4 tires is pathetic compared to the R1s. It’s like nascar tire spinning on ice. As others mentioned the bucket is a necessity to move the tractor when finding yourself in that condition. The R1 tires had their issues with mud too, I’ve gotten in positions where I could not push into dirt/mud to lift it or unable to pull the box blade forward. However, they would always go without help in the thickest mud. The R4 tires don’t steer well in the mud, and the R1 tires did not usually have that issue.
Damage to my yard during soft winter conditions of the thaw season still happens with the R4 tires. The ruts are not quite as deep and the water does not pool in the ruts allowing the water to drain better from them. Damage to my gravel driveway is far less with the R4 tires versus my previous R1 tires especially when turning in a tight radius.
I got the R4 tires based on my usage and damage to my yard and driveway. I hope I don’t regret it when mowing on the hillside.
I never had issues with punctures on my last R1s. We had a house built and they were very careless with nails along with other materials. Plus I did a lot of brush clearing in wooded areas and took out a couple barb wire fence lines. Now my smaller tractor before I did manage to get a hole in one of the fronts and I discovered it already had a tube. I just put another one in it.
If you want maximum traction on dirt and mud no doubt get the R1 tires, especially for ground moving implements. If you’re lifting and doing more construction oriented things, or lots of snow removal, then R4s.
Also, I have always had my rear tires loaded. My last tractor also had the fronts loaded which I think helped for turning.
Matt
Ps: This is what I was into earlier this week preparing for the flooding we are getting now. I used the loader to make that big pile after I reduced the elevation to promote drainage in this area until I can fix the mess come dry weather. The mud was about 6-8” deep, just below the top of my mud boots in some places.
   / Ag vs. Industrial tire strengths #12
I have tractors with R1s, R3s, and R4s, and none of them are worth a Dxxx in the snow without tire chains. Loaded tires are very important, especially with the huge lifting power of today's FELs. However, I would skip the juice and get cast iron wheel weights. Pay more up front, but never having to fight a 500lb tire or worrying about fluid leaks/repairs is priceless.
   / Ag vs. Industrial tire strengths #13
R1/ag tires provide better tractive power. Especially important working on hillsides, where wheel slip can potentially result in tractor rollover.
R1s can be special ordered with 6-ply and 8-ply rather than standard 4-ply, possibly more. As ply count increases, rigidity increases and traction very slightly decreases.
R1s with bar tread are prone to marking lawns where R4s do not.
   / Ag vs. Industrial tire strengths #14
I ran Ag tires my whole life until my last tractor purchase. I prefer Ag's. If I could get a 12 or 14 ply tubeless in a R1 tire I would jump all over it. My current 8 ply R4's mounted on my Workmaster 50 are more puncture resistant than the 4 ply Ag tires currently mounted on my Ford 4610 SU. Makes sense since they are thicker. That is about the only advantage I see in them on the rear. On the front R4's are better for FEL's that have high lift capacities. I always load the rears.
I'm getting ready to mount a pair of 12 ply R4's on my Ford 4610 SU. I use it to brush hog and hope for increased thorn resistance. I mounted 18 ply aircraft tires on the front from Gensco. They are the cats meow.
   / Ag vs. Industrial tire strengths #15
I have R4s, I have to have the tractor in 4wd to push 6in of snow without chains and the tractor is 5300lbs.
If buying new I would go turfs and only the Multi Trac tread, they are better in snow, as good as R4s in mud and better on the lawn.
Lots of guys on here skid logs in the woods with turfs.
   / Ag vs. Industrial tire strengths #16
When we put new tires on the 265 MF Ag 12 ply were just about $50 more that the 6 ply version but they were dirty and jobber may have just wanted to get rid of them. I already had prices on the 6 ply and went back to see if the dealer could get a stronger version because I have been known to use the heavy duty bush hog to the max.
   / Ag vs. Industrial tire strengths #17
I have got tire punctures on my Ag Tires while logging and other places, but it always happened when my tires were worn down. When the lugs are thick, it typically is enough to keep the weaker parts of the tires from getting into trouble. They were just plain worn out and broken down tire wise. It got to the point where I could change a front tire and patch it (or replace with new tube) and have it back on in 20 minutes. Now that I got new tires, I have yet to have a single puncture; tread makes the difference.
I have no opinion per se over R1 vs R4 as I have a farm and I need ag tires because I do ag work.
   / Ag vs. Industrial tire strengths #18
Tubless dry tires can usually have the leak plugged in the spot without removing the tire from the rim. Bonous points for not being sprayed with liquid ballast .
   / Ag vs. Industrial tire strengths #19
If you want maximum traction (without the use of tire chains) go with R1 radial ply tires. Just don't look at the sidewall bulge. :eek:
   / Ag vs. Industrial tire strengths #20
I agree, and anything to eliminate tire chains is a very good thing. They are a pain to put on, and often keep on.
I never understood the tire bulge thing: just wind 60 PSI into the tires and the problem goes away.
VOLVO SD75B SMOOTH DRUM ROLLER (A60429)
VOLVO SD75B SMOOTH...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
2008 Dynapac CA150D (A60462)
2008 Dynapac...
DEUTZ MARATHON...
2002 Kenworth T300 TMA Truck (A55973)
2002 Kenworth T300...
1959 DODGE D510 DUALLY FLATBED TRUCK (A60430)
1959 DODGE D510...
