sixdogs
Super Star Member
- Joined
- Dec 8, 2007
- Messages
- 13,524
- Location
- Ohio
- Tractor
- Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I have a toolbar like the one shown here and want to add an extension on each side:
The above photo is off the net.
It's 2 1/4" tubing that's 1/4" thick and mine is 42" wide. I would like it to be 14" wider on each side. Since I'm not a regular welder, can I weld a 14" piece of the same tubing on each side and will it be as strong as the tubing itself? I want to use it as a cultivator and there will be pretty good pressure on it. I thought of slipping a piece of 2" tubing inside as extra support but there is a small seam inside that seems to prevent that idea. It's not easy to just replace the tubing because of it's design.
I am capable of making a good penetrating weld on this but have never done such a project and my dumb question is will it work? I know the weld is supposed to be as strong as the metal itself and I have not had a weld failure since my learning days but I thought to ask you guys here since you weld every day and already know the answers. Any advice appreciated.
