John Deere 820 Hydraulic Fluid Pressure & GPM specs?
   / John Deere 820 Hydraulic Fluid Pressure & GPM specs? #1
Rainboy
Romney WV
john deere 820
We're looking at installing a 3 point hitch-mounted (BOSS) Log Splitter on our John Deere 820. The specs show it runs about 2100 psi, but I can't find the GPM flow rate.
?Can anyone provide the GPM flow on this tractor? AND Is this a good idea to use the tractor 3 point to spit logs. Boss says it should be 8?5 GPM at 1500-2000 PSI?
Thanks in advance.
   / John Deere 820 Hydraulic Fluid Pressure & GPM specs? #2
I've never used a three point log splitter, but the hydraulics on your tractor will be more than enough
   / John Deere 820 Hydraulic Fluid Pressure & GPM specs? #3
While they do work, 3 point log splitters are painfully slow most of the time when run off of the tractors hydraulic system. I have seen a few that use a PTO driven pump and those seem to work better.
   / John Deere 820 Hydraulic Fluid Pressure & GPM specs? #4
I think the open-center hyd's on a 820 with 3cyl engine will operate a log spitter very slowly.
   / John Deere 820 Hydraulic Fluid Pressure & GPM specs? #5
Tx Jim did you get a email from me? Lee
As said the tractor hyd flow would be way to slow.
   / John Deere 820 Hydraulic Fluid Pressure & GPM specs? #6
Tx Jim did you get a email from me? Lee.
Lee
I just sent you a reply. IMHO TBN leaves a little to be desired on PM notifications as I was unaware that you had PM'd me.
Jim
   / John Deere 820 Hydraulic Fluid Pressure & GPM specs? #7
An 820 3 cylinder at rated speed will make a full stroke cycle in about 30 seconds using a 5x24 cylinder. Pretty slow imo.
Volvo ECR235CL (A53317)
Volvo ECR235CL...
2014 Chevrolet Tahoe 4x4 SUV (A55853)
2014 Chevrolet...
2014 Chevrolet Tahoe SUV (A55853)
2014 Chevrolet...
30pc 3ft. x 8ft. Red Polycarbonate panels (A53424)
30pc 3ft. x 8ft...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
