OP
sixdogs
Super Star Member
- Joined
- Dec 8, 2007
- Messages
- 13,524
- Location
- Ohio
- Tractor
- Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
When splicing square tube, or any tube, using an insert plug welds are your friend. Plug welds a couple of inches out from the splice point.They'll take a lot of stress off the weld itself.
Having said that, I'd consider a truss type gusset either forward or reward to take some of the stress off those ends way out there.
Explain this a little better. Do you mean to drill a hole in the outer tubing and weld that inside onto the inner support piece?
My plan is to make the inner piece long enough so it's almost to the end of the outer piece and then weld those two together at the end.
