What would actually happen if teflon tape flaked off into the hydraulic system?
   / What would actually happen if teflon tape flaked off into the hydraulic system? #11
For a piece of teflon tape to get into a .0003 space...it would have to be <.0003 itself...
That would be true if the Teflon was a hard piece of material but in a hydraulic oil system that is running and heated up think of it more like an ugly piece of play dough being pushed by 2000+ psi into whatever crevice available.
   / What would actually happen if teflon tape flaked off into the hydraulic system? #12
Does not make any difference...any particles would still have to be smaller...
   / What would actually happen if teflon tape flaked off into the hydraulic system? #13
"Just say NO" to teflon tape in hydraulic applications.
See! Wasn't that easy?
   / What would actually happen if teflon tape flaked off into the hydraulic system? #14
Not sure why this topic comes up all the time...it is hardly a big issue...I don't recall it ever being found to be a problem by TBN'ers other than for a moot arguing point...
All the do/don't points have been made hundreds of times...everyone wants to think they only use ideal methods and sealants...
IMO hardened crystals of liquid sealants introduced from the reuse of fittings are no different than bits of tape...
prudence rules...
IMO a much more likely scenario for foreign matter getting into typical non professional tractor hydraulic systems is via quick disconnects...they often have oil residue on them...tractors operate in dusty, dirty, gritty conditions...wind blown grit easily sticks to greasy QD surfaces...wiping them off with a gritty rag does no good at all and particles (granite dust for instance) that can't be seen can cause real issues...Every time a QD is disengaged/reengaged the system is open and vulnerable to foreign material...
Teflon tape is proven to work for most intended applications...any real or imagined issues can be 100% avoided...as long as one is aware it's a non issue...
   / What would actually happen if teflon tape flaked off into the hydraulic system? #15
Because the .0003" clearance passage is much much larger with the valve being actuated.
You can't fit a 2x4 through the crack in your door. But open the door and it fits fine right.....
Now with the 2x4 half in and half out....try closing the door....
Do you get a good seal?
Same problem
   / What would actually happen if teflon tape flaked off into the hydraulic system? #16
Same problem
the same scenario can happen with hardened chunks of locktite or other sealants...
   / What would actually happen if teflon tape flaked off into the hydraulic system? #17
Keep using tape then.
Tape has been proven to cause problems.
Never heard of a single case where Loctite 545 caused a problem.
   / What would actually happen if teflon tape flaked off into the hydraulic system? #18
Any contaminate can cause problems...a microscopic flake of hardened sealant is the likely cause of many o-ring failures that simply don't get associated with sealant crystal chips etc...
   / What would actually happen if teflon tape flaked off into the hydraulic system? #19
I had someone recommend as an alternative to using tape, to simply oil an NPT fitting before making it up, to keep the threads from galling before fully seated. I started doing that, and in my very limited experience, so far it seems to work. Especially on NPT "swivel" fittings.
   / What would actually happen if teflon tape flaked off into the hydraulic system? #20
If by NPT swivel you mean NPSM fittnigs (look kinda like JIC only the seating cone is inverted)....then those dont need anything. ITs a mechanical seal just like JIC
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1ET4EKG11918 (A54865)
2014 Ford F-150...
2012 VOLVO BL70B BACKHOE (A51246)
2012 VOLVO BL70B...
1065 (A53342)
1065 (A53342)
2017 DRAGON 150 BBL ALUMINUM TRAILER (A53843)
2017 DRAGON 150...
2000 Sterling L9513 Winch Truck (A55302)
2000 Sterling...
2002 Bobcat 763 High Flow Compact Wheel Loader Skid Steer (A55851)
2002 Bobcat 763...
