JD 2440 Splitting & Disassembly Issue, Independent PTO (Less Hi-Lo & Reverser)
   / JD 2440 Splitting & Disassembly Issue, Independent PTO (Less Hi-Lo & Reverser) #11
Re: JD 2440 Splitting & Disassembly Issue, Independent PTO (Less Hi-Lo & Reverser)
All 2440's prior to serial number 341,000 had brake band with independent pto. 341,000 and up could have had either, depending on configuration as TxJim mentioned.
   / JD 2440 Splitting & Disassembly Issue, Independent PTO (Less Hi-Lo & Reverser) #12
Is this the serial number, 341,00 up, when the syncro trans was first available?
   / JD 2440 Splitting & Disassembly Issue, Independent PTO (Less Hi-Lo & Reverser) #13
IIRC TSS(synchronizer) trans wasn't offered until 50 series utility tractors.
   / JD 2440 Splitting & Disassembly Issue, Independent PTO (Less Hi-Lo & Reverser) #14
I was thinking late 2X40 series, but not sure.
   / JD 2440 Splitting & Disassembly Issue, Independent PTO (Less Hi-Lo & Reverser) #15
I didn't locate any synchronizers in drive train section in late model 2440 parts catalog BUT it's possible I overlooked them.
   / JD 2440 Splitting & Disassembly Issue, Independent PTO (Less Hi-Lo & Reverser) #16
OK, I did some parts catalog looking too. Late 2040 & 2240 had syncro transmission option. Late 2440 & 2640 did NOT have syncro shift transmission.
I'd like to replace the 2030, mainly to get away from the collar shift transmission. So 2440 is out, 2640 is bigger than I need/want, but also out.
   / JD 2440 Splitting & Disassembly Issue, Independent PTO (Less Hi-Lo & Reverser) #17
It's odd that the smaller tractors of same era had synchronizer trans but the next size larger ones didn't. I guess you'll have to step up to a 50/55 series You would love a 2355 or 2555 that have the gearshift levers moved forward from trans hump.
Case 650K Series 2 LGP Crawler Tractor Dozer (A51691)
Case 650K Series 2...
2009 Peterbilt 335 Cab and Chassis Truck (A51692)
2009 Peterbilt 335...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A53473)
John Deere 5090E...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2024 PETERBILT 389 TANDEM AXLE SLEEPER (A53426)
2024 PETERBILT 389...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A53426)
2018 FREIGHTLINER...
