Maintenance of Rotary Cutters Vs Flail Mowers
   / Maintenance of Rotary Cutters Vs Flail Mowers #11
The side sliders on my 917 held up fine with no maintenance or sharpening other than replacement when worn or mangled. I abused them too, lots of rock strikes from gravel. It was an old beater I paid $100 for so didn't care much. The thin material of the side slicers is still pretty thin even when dull, so still cut well.
My new Peruzzo is gonna be a different story. I have thick hammers on it, so I imagine dulling & sharpening on those will be an issue. Not to mention paying a LOT more for the new machine.
   / Maintenance of Rotary Cutters Vs Flail Mowers #12
Hello Fallon,
Once you use a wet well grinder to maintain the edge of the cast hammers and side slicers you will be amazed at the cut quality.
   / Maintenance of Rotary Cutters Vs Flail Mowers #13
I dunno. Watch me replace my blades on my rotary cutter (among other things).
Wow! That's a whole lot harder than with my Bush Hog cutter. As long as you have a big socket (inch and a quarter or thereabouts) and do it every two or three years it's no big deal. Remove the nut and drive out the shoulder bolt (hint, a hand drill - small sledge hammer - makes a perfect punch and holds itself in the hole in the deck. The bolt and blade drop out and are easy to sharpen on a bench grinder. Reaching under to re-assemble is a bit awkward but it fits together tight enough to hold itself in place until you can get the nut on.
About 30 to 45 minutes for both I'm guessing. But a lot more trouble getting it out if you wait 10 years for the first time - don't ask how I know that. :eek:
   / Maintenance of Rotary Cutters Vs Flail Mowers #14
It would have been a lot simpler if the two shims had not mushroomed. Now that I've "fitted" my shims and anti-seezed the pins, I expect that a 2 pound mallet will knock the pins out next time around.
   / Maintenance of Rotary Cutters Vs Flail Mowers #15
I said this on the Marathon Flail thread here on TBN and got pounced on by the dedicated Flail crowd. :)
I don't understand all the hype regarding Flail mowers.
I saw your post and tend to agree. If I could clear banks and ditches with my Brushog, I wouldn't be buying a flail. It's mainly one with offset and vertical cutting capabilities that makes a flail useful to me.
   / Maintenance of Rotary Cutters Vs Flail Mowers #17
I own one because I got it very cheap. But then cheap cost isn't relevant to high operating expenses. I've spent over $500 on it in the past two years. I'm just trying to recoup my costs. :)
   / Maintenance of Rotary Cutters Vs Flail Mowers #18
I use a sickle mower for ditch banks and such, even trim trees along the drive with it.
   / Maintenance of Rotary Cutters Vs Flail Mowers #19
IMHO THEY ARE BOTH MOWERS BUT FOR DIFFERENT TASKS YES THE ROTARY MOWER WILL CUT HEAVIER BRUSH BUT DOES NOT LEAVE AS NICE CUT THE FLAIL LEAVES A FINE CUT AS WELL AS MULCHING UP WHAT YOU MOW OVER BOTH HAVE THERE PLACE I HAVE BOTH AND USE THE ONE THAT I NEED AT THE TIME. AS FOR MAINTAINING THE ROTARY WILL REQUIRE LESS AS THE FLAIL HAS MORE MOVING PARTS THE COST IS BIG ISSUE YOU CAN BUY A GOOD ROTARY FOR A THIRD OF PRICE OF A FLAIL UNLESS YOU FIND USED WOULD DEFINITELY KEEP ROTARY MOWER TO USE WHEN I NEED IT.
   / Maintenance of Rotary Cutters Vs Flail Mowers #20
I doubt anything can compare to a rotary mower of sufficient size for the tractor and job to be done. Fewest moving parts and built like a tank. With that said, it's amazing how nice of a job you can get done with one, especially on flat, level ground and turf to cut.
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
Jack Daniels Wall Art (A55853)
Jack Daniels Wall...
2020 John Deere 450M Round Baler (A53485)
2020 John Deere...
2019 Autocar ACX Xpeditor T/A EZ-Pack Front Loader Garbage Truck (A55852)
2019 Autocar ACX...
1656 (A57192)
1656 (A57192)
Mahindra 4550-4L Tractor with Front Loader - 49 HP, 4WD, Heavy-Duty Utility (A55315)
Mahindra 4550-4L...
