Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #5,502
   / Tractors and wood! Show your pics #5,503
Hey OldP I guess we both know that if you cut enough trees a pinched saw is going to happen some where along the way. Looks like you got it on the ground OK. I see your wood pile is growing pretty good.
gg
   / Tractors and wood! Show your pics #5,504
I went to the Log Yard today to pick up last weeks check. The piles are getting big so took a couple pictures. This is just the Spruce/Fir pile and I couldn't get it all in with 2 shots. Not every stick was mine, I got some help from a few local boys :D
gg
   / Tractors and wood! Show your pics #5,505
I am always afraid they will go backwards on top of me. So I strap up high, rope/chain WAY back and pull it my direction. I see your L3400 ROPS is super stout. Did you make it?
Yup, one of the first things I made I didn't think the standard ROPs give enough protection. The whole cage can be taken off by unbolting if this tractor ever sees farm work.
Gotta be careful when doing this,tree could break off of stump and fall back over the bucket and onto you,ask me how I know. Better to pull with cable and winch.
40 years ago when I first started cutting wood for someone with a JD440 skidder, I was cutting a big ole scrub pine for a load of pine pulp, pinch my saw, waited for the boss to come back in, he put the blade against the big pine, I got my saw out and backed away, the boss started to push hard on the scrub pine, it snapped off the stump fell back on the skidder, bout buried it, he gave that skidder full throttle, forward and back, wiggled it, after 15 minutes he got it out from under then he cussed me out, so yeah I learn one important lesson, Cut higher on back and leave a good hinge.
With a double-stem tree like that, I always cut one stem at a time. Never mind the wind -- the problem as I see it is that you didn't have a predictable way for gravity to act on the notch and hinge in a specific direction. I'm not surprised it sat on the saw.
Oh I had a predictable way for the tree to go and it did go that way with help from the tractor. It would've gone by itself to but I just did get around the other side with the back cut enough, I just assume I did without looking and the wind was gusting to 40 mi/hr against the tree and the wind just blew it back on the bar and since I knew I had a good hinge left on the double tree, I just put the bucket against it and tilt it,and wahala, course a couple wedges and an axe could of done the same thing.
   / Tractors and wood! Show your pics #5,506
gg
Yeah I know right, you know how it is...............
   / Tractors and wood! Show your pics #5,507
gg
So where is all that spruce and fir going? And I thought I was piling the wood high.......................
   / Tractors and wood! Show your pics #5,508
A good amount goes to Canada. 40 miles north straight up Rte 91. Logs head north, dimensional lumber comes back. Saw Mills here going broke. Hard to figure. The rest I have no idea where it goes. Stud mills NH and Maine probably get a fair share.
gg
   / Tractors and wood! Show your pics #5,509
Same here, most logs go to Canada, comes back as lumbur at HD. We can get by nowadays with using less paper and we probably dont need so many paper mills like 50 years ago, but building houses still needs lumber.
   / Tractors and wood! Show your pics #5,510
30+ years ago, I had almost an acre cleared of medium to large fir/cedar/hem-fir in the Seattle area. I sold the logs to pay off the excavation and foundation work for my future home. I got the best rate going to Canada even with the extra truck mileage. Seems times haven't changed.
Galvanized steel Fence (A53424)
Galvanized steel...
300# CLUTCH JACK (A53843)
300# CLUTCH JACK...
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A53426)
2007 PETERBILT 379...
CATERPILLAR 140M2 MOTOR GRADER (A52706)
CATERPILLAR 140M2...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A54814)
2021 International...
